Playing around with my Philips NMS9100 XT.
First I found out the ATI Graphics Solution-SR originally in the system wasnt really working in graphics mode a lot. Still not sure why, should be no problem. Will revisit later if I feel bored and the need to keep the original graphics card in the system. Swapped it for an ATI VIP and the Hercules stuff is up and running.
Then I decided I needed some storage, so on a whim I tried flashing the XT-IDE Universal BIOS on an EEPROM and putting it in a network card, a Realtek. Didn't work immediately, but found that I should enable the Boot ROM on the card. To my surprise, I found the utility for that on the Realtek website and was able to run that on the XT to setup the network card. Wow!
Now the XT-IDE ROM loads, but as soon as I put in a controller the PC won't boot from floppy anymore. I disabled everything on the controller except HDD but not working. Will try another one tomorrow, if can find one in the heap.
Snark Barker workes like a charm in this system. 😀
