Reply 13060 of 31625, by Ultrax
oeuvre wrote:
this was the worst PC beep I've heard, from some old Gateway 2000 motherboard
Tell Gateway to stop hiring truck horn engineers to make their motherboards!
Ultrax
__
Presario 425|DX2-50|8MB|SB V16S|D622/WFW3.11 😎
Deskpro XE 450|DX2-50|32 MB|NT4.0/95
SR2038X|Athlon 64 X2 3800|2G|GT710 WINXP
Dimension 4400|P4 NW 2 GHz|256M|R128U AGP|WINXP
HPMini311|N270|2G|9400M|WINXP
Libretto50CT|P75|16MB|YMF711|WIN95 😎
Reply 13061 of 31625, by Ultrax
AC adapter for my Libretto 50CT finally arrived today. I LOVE THIS THING! Even the sounds it makes are just like that of a normal, big Pentium MMX machine, but I can comfortably curl up on my bed and enjoy all sorts of games with this!
Ultrax
__
Reply 13062 of 31625, by Predator99
Now have the 1st of my 9 Philips XT boards running!
Re: Bought these (retro) hardware today
Before:
The attachment IMG_5333x.jpg is no longer available
After:
The attachment IMG_5365.JPG is no longer available
After having Supersoft running without errors on CGA, it was quite difficult to make it boot with a normal BIOS. The CGA card didnt work at all, and the board was quite picky about the VGA. An ET4000 did it. In between C22 beneath the power supply exploded, but it also runs without it.
Regarding the BIOS I tried many. TURBO XT BIOS and mony others dont display anything on all cards. Award complains about parity and doesnt let me continue. Phoenix finally works! Dont have the sockets to install the parity, but it works without, too.
Think a main problem is, that the DIP settings dont change in Supersoft when switching. So the BIOS thinks all the time a MDA is installed. The DIP seems to be specific for this board.
On-board floppy also seems to run. The 8-bit IDE interface is not compatible, so I used XT-IDE with a 16-bit controller.
And still interested in the original BIOS 😉
The attachment IMG_5359.JPG is no longer available
The attachment IMG_5362.JPG is no longer available
The attachment IMG_5363.JPG is no longer available
Reply 13063 of 31625, by rick6
I've been messing around with retrobright for the first time. Now it's time for bigger computer parts!
The attachment IMG_20191006_003104.jpg is no longer available
The attachment IMG_20191001_082405.jpg is no longer available
The attachment IMG_20191001_082346.jpg is no longer available
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 13064 of 31625, by kolderman
That's probably the clearest demonstration that retrobrighting can work I've seen.
Reply 13065 of 31625, by Caluser2000
I turned off my 486.
The attachment 20191006_190829[1].jpg is no longer available
Reply 13066 of 31625, by Caluser2000
Then I got so enthusiastic I turned the 386 off as well.
The attachment 20191006_200749[1].jpg is no longer available
Special back ground lighting supplied by a $2 shop translucent torch.
Reply 13067 of 31625, by yawetaG
Late yesterday evening I concluded I own two shareware compilations I must absolutely upload somewhere, because they are mid-1990s dumps of large BBS'es and full of shareware programs, drivers, and documents that people here will love (for the sound freaks: two folders full of MOD utilities, FM OPL2 programming stuff, etc.)
Reply 13068 of 31625, by Caluser2000
Sounds great.
Reply 13069 of 31625, by kixs
Repaired battery damage on SOYO 025D2 486 VLB board. Keyboard wouldn't function because of one broken trace. All good now 😀
Link to the board settings as I'm messing around with it right now 😀
https://stason.org/TULARC/pc/motherboards/S/S … 6-486-VESA.html
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 13070 of 31625, by Bruninho
Watched the new Carmen Sandiego netflix show, then fired up my dosbox to play the classic game.
“Ready for your next case, Bruninho?”
#nostalgiaAlert
And thinking about reorganizing my entire virtual machines archives.
Probably the following setup:
MacBook Pro
- DOSBox: Windows 3.1 without networking (replicating my 1st ever pc interaction)
- Virtualbox or VMWare Fusion (undecided yet): Windows 9x, or Windows 2000, or Windows Me? I want the classic 9x environment with the best possible internet experience available. I thought about using Windows 7 with a Classic Theme patch that is around. I have a Windows 10 VM that I will keep with me for a while before I make the jump to a Bootcamp based install, just for some heavy games but need to do a few more experiments and tweaks. The VM will be reset for use at work later - to do web development tests. I have product keys for all of the above.
iPad Pro
- DOSPad: Windows 3.1 without networking (same as above).
JOBS, Steve.
Reply 13071 of 31625, by Caluser2000
Preparing a 3.6volt TADIRAN external battery pack for reuse.
The attachment 20191007_181025[1].jpg is no longer available
Reply 13072 of 31625, by CBM
for the longest time, I have been deeply engulfed in GZDoom activities.. that is... downloading mods, modifying them and merging them... to create a very nice modernish and highly cuztomized doom experience...
for example.. I have a modified wadsmoosh that will allow me to play any combination of doom, doom2, heretic and hexen maps... working on adding strife to the mix as well
I strictly use 3D models for everything so currently I am limited to Doom and Heretic monsters and a few Hexen monsters, I have plenty other 3D models though.
I also added civilians from genetech, since some maps (for example city of the damned and ofc genetech) and/or games (strife) use civilians
I even created skins for some of the existing doom md2 models so they could represent the skulltag monsters defined on the ZDoom wiki 😁
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 13073 of 31625, by Duouk2000
I've purchased a lot of cheap PC games for 50p and a quid over the past few weeks. Stuff like Dungeon Siege, Splinter Cell, GTA 3, Rise of Nations, Return to Castle Wolfenstein...etc.
I decided now would be a good time to rip them all along with any other games that still need doing. At some point I need to put everything on a home server I can access from any PC in the house.
Reply 13074 of 31625, by 4dam
I've cleaned up Radeon 9000 PRO with distilled water and dish soap.
Instagram Retro
Reply 13075 of 31625, by Duouk2000
Looks as good as new! I was so envious of these cards when they came out.
Reply 13076 of 31625, by FAMICOMASTER
Love that red cooler on the black PCB!
Is that 128MB?
Reply 13077 of 31625, by kaputnik
Designed and 3d printed a custom sleeve to accommodate a larger and less noisy CPU fan in the SS7 build I'm working on:
The attachment shroud1.PNG is no longer available
The attachment DSC_0323.JPG is no longer available
The attachment DSC_0324.JPG is no longer available
Reply 13078 of 31625, by Cyrix200+
Playing around with my Philips NMS9100 XT.
First I found out the ATI Graphics Solution-SR originally in the system wasnt really working in graphics mode a lot. Still not sure why, should be no problem. Will revisit later if I feel bored and the need to keep the original graphics card in the system. Swapped it for an ATI VIP and the Hercules stuff is up and running.
Then I decided I needed some storage, so on a whim I tried flashing the XT-IDE Universal BIOS on an EEPROM and putting it in a network card, a Realtek. Didn't work immediately, but found that I should enable the Boot ROM on the card. To my surprise, I found the utility for that on the Realtek website and was able to run that on the XT to setup the network card. Wow!
Now the XT-IDE ROM loads, but as soon as I put in a controller the PC won't boot from floppy anymore. I disabled everything on the controller except HDD but not working. Will try another one tomorrow, if can find one in the heap.
Snark Barker workes like a charm in this system. 😀
1982 to 2001
Reply 13079 of 31625, by FAMICOMASTER
Got myself a monochrome monitor in today. Not sure if it works, but I'm going to clean it up before I even think about testing it!
Will be using it with my turbo XT soon if it works!
EDIT: Added picture
