Reply 31180 of 58849, by Predator99
Tiido wrote:
That's certainly an improvement ! You'll want to do a needle test on the chips. Take a needle and skate it strongly across the pins to find any bad solders. Chances are some pin is not connecting right and causes the problem.
Are the missing sounds always the same and are any sounds outright wrong or random ?
I removed the card, pushed on some ICs and I am quite sure it sounds different now...seems to be loose contact indeed. Seems not to random, always the same instruments are missing/sounding weird.
Reply 31181 of 58849, by dionb
Last week I posted some frustration at being outbid on something. Not for the first time being polite and responsive turned out a better strategy in the end. The higher bidder just stopped communicating with the seller at some point, so I got lucky after all.
Please meet the fastest 386SX out there:
The attachment 15736771973560.jpg is no longer available
Alaris Leopard rev C with IBM 486SLC2-66 and an IIT co-pro for good measure.
First job has already been seen to: removing the Varta time bomb. Fortunately the board has an external battery header, so hooking up the replacement is easy.
Also maxed out the RAM to 16MB. Tried to do the same with L2 cache but it didn't like my chips. Need to look into what's going on there. Still, 16kB L1 and 64kB L2 is more than most CPUs with 16b memory bus can brag of.
Next step is to benchmark my ISA and VLB VGA cards on it to see how they scale with this CPU/bus, then decide which to use with it permanently. Also (and relevant to that choice) I need to figure out what to do with the system as a whole. IBM design just begs for OS/2 I suppose...
Edit:
Cache problem was simple - with onboard 64kB cache it only needed a 64kbit tag. Replaced that with a 256kbit tag and it suddenly worked fine with 128kB L2 😀
Reply 31182 of 58849, by imi
imi wrote:
when one G200 simply isn't enough 🤣
pic
The attachment hardware33_01.jpg is no longer available
when one quad G200 simply isn't enough 🤣
The attachment hardware33_01b.jpg is no longer available
I like how they one time think they need heatsinks and one time they don't
also rather nice surprise with this "mystery" PC, I didn't really know what I was getting but I assumed 286 and I wanted the EGA card anyways...
assumed correctly, and a nice one at that... in need of immediate battery amputation, there's quite nasty corrosion on the keyboard connector but the board looks like it may survive, the big trace looks a bit tarnished... hope there's no surprise on the underside though.
The attachment hardware33_03.jpg is no longer available
edit: how can I quote my own images?
Reply 31183 of 58849, by HanJammer
Nice Morse Suntac motherboard!
No need to hurry with the battery removal - if it didn't leaked yet, it's not going to anytime soon. It's GP anyway and they don't leak or just get a little corrosion on the terminals.
Reply 31184 of 58849, by imi
well it did leak already, there's heavy buildup on the top of the battery and the keyboard connector, and the big traces on the board look a bit darker around that area... didn't get to it today, but it'll be the first thing I'll do tomorrow when I get home 😀
Reply 31185 of 58849, by Horun
Intel486dx33 wrote:
Royal Mail from England.
2 NEW never used IBM Blue lighting’s
Nice ! Have never owned an IBM 486. So 3L 45p for airmail ? That is about $4.50 us. How much for the two DX2-66 ?
Reply 31186 of 58849, by bmwsvsu
Box of 170 random new-old stock I/O shields for $21. About 12 cents a piece.
Quite a bit of variety of stuff in here. While some of it is for newer boards, there's a fair amount for motherboards made before 2005.
You can never have too many I/O shields when so many people sell boards without them.
Reply 31187 of 58849, by xjas
^^ oh, so THAT'S where they all end up.
Reply 31188 of 58849, by dr.ido
One of these was my first "486" back in the day. I traded a Commodore 1084 monitor for this board and a 170MB IDE HDD. I get it home, swap out my 286 board and nothing! I eventually work out the somehow the only VGA card I had wasn't compatible with this board - I ran my new "486" with for a couple of weeks until I could scrounge up another VGA card.
Reply 31189 of 58849, by imi
mine has the exact same botchwire, guess they came from the factory like that ^^
I don't have a matching FPU for it though.
Reply 31190 of 58849, by keropi
yes the wire is a factory patch, I used to have this board as well
Reply 31191 of 58849, by bmwsvsu
Scored a box of 11 brand-new (old stock) Pentium-III PGA 370 motherboards for $92, so that's just over $8 per motherboard.
These are OEM Gateway boards with 2 PCI slots, made by MSI, model MS-6312. Unable to find out much about this board online other than a lengthy thread suggesting that these boards are notorious for having bad caps. So I may end up with a pain-in-the-butt recapping project on my hands depending on what these look like.
Back panel is kind of lacking in ports - it does have 3 USB ports and a parallel port but is lacking a serial port and PS/2 ports. So I'll have to settle for Keyboard/mouse emulation over USB. Should be able to connect the 2 front ports in my case to the lone USB header, thus giving me 5 USB ports in total. Board does have a COM header so I can add a serial port if I decide to in one of the free PCI slot areas. The 2 PCI slots are just enough to set this up with a PCI sound card and video card. Has an Intel 810 chipset which looks to be friendly to PCI sound cards in DOS mode.
Reply 31192 of 58849, by derSammler
It has on-board VGA. Not sure what games you want to play on these, but the on-board video card may be good enough.
It has on-board sound as well...
Reply 31193 of 58849, by dionb
Out of interest: which card didn't work?
So far I've run it with CL and S3 cards with no trouble at all. Having some issues with turbo LED - but turbo itself works fine, slooooooow with turbo off 😉
Reply 31194 of 58849, by Predator99
imi wrote:
also rather nice surprise with this "mystery" PC, I didn't really know what I was getting but I assumed 286 and I wanted the EGA […]
Hi Imi, nice PC and nice board! Think I have the same one here
Re: Suntac 80286 Mainboards
Can you also post pictures of the EGA-card and the case please? Whcih BIOS revision does the board have?
Reply 31195 of 58849, by mpe
Caching SCSI controller for my upcoming EISA 486 build.
Blog|NexGen 586|S4
Reply 31196 of 58849, by bjwil1991
Wow. That is really neat. Is it both internal SCSI and external? My eyesight isn't the best.
Reply 31197 of 58849, by imi
yeah, I recognized it because you posted about it before 😀
The attachment hardware33_03a.jpg is no longer available
I snipped off the battery and cleaned off most of the corrosion for now, interestingly enough the battery terminals themselves aren't really corroded but the keyboard connector needs to go probably and one of the AT power pins was corroded on the backside, also one trace on the back might need repair, otherwise it looks in good shape.
The attachment hardware33_03b.jpg is no longer available
unfortunately there are no markings on the bios chips, interestingly enough they're factory marked on the chip directly, so I assume it's a very early version probably?
so that'll have to wait until I get around to testing it.
it also came with this nice matching full size MFM controller
The attachment hardware33_04.jpg is no longer available
the EGA card is another Genoa Super EGA Hi-Res, already got another variant of these, it is my first ever GPU of my first PC, I don't know which version exactly I only know the model from the original manifest I still have, in any case having different variants can't hurt 😀
The attachment hardware33_05.jpg is no longer available
the case... you're not gonna tell me now you made me pay more for it, are you? :p
it's nice, as I already had another one of these too 😀
The attachment hardware33_06.jpg is no longer available
Reply 31198 of 58849, by gex85
I've been in a bit of a retro pc shopping frenzy lately...
Still being on the hunt for a decent AT midi tower case for my Tyan Trinity based SS7 build, I came across a nearly complete system on eBay (seller's photo):
The attachment s-l1600.jpg is no longer available
This thing has a working Commate S7AX mainboard with an AMD K6-2 333 MHz, 128mb of RAM, an S3 Trio graphics card and some generic CD-ROM drive in it, missing only the hard disk. As a bonus, it comes with an iomega Zip drive, which seems to become my standard for exchanging data between retro PCs, because somehow nearly every pre-2000 build seems to be equipped with one...
Being the only bidder, I got the whole thing for 35€ + shipping which is not a terribly good deal, but still okay. Since I already have all components that I need for my build, the board + CPU will probably go back to eBay very quickly.
Other things I bought this week:
- The 30€ lot with the Rage Fury MAXX in it (arrived yesterday, card is in excellent condition and seems to work fine, might post some pictures later).
- Another lot with various VGA cards, network cards and optical drives, details remain unknown until the package arrives. Was only 10€ so I got it mostly because I was curious what the VGA cards are, and I am running short of network cards anyway
- An AWE 64 Gold for around 40€, which is well below the price these things tend to go for lately (60-70€) but still a bit to much to call it a bargain
My retro computers
Reply 31199 of 58849, by Predator99
Thanks, very nice!! No, I usually dont bid on full systems. Prices are too high and I dont have space left...
