Reply 31180 of 56748, by dionb
- l33t++
Last week I posted some frustration at being outbid on something. Not for the first time being polite and responsive turned out a better strategy in the end. The higher bidder just stopped communicating with the seller at some point, so I got lucky after all.
Please meet the fastest 386SX out there:
Alaris Leopard rev C with IBM 486SLC2-66 and an IIT co-pro for good measure.
First job has already been seen to: removing the Varta time bomb. Fortunately the board has an external battery header, so hooking up the replacement is easy.
Also maxed out the RAM to 16MB. Tried to do the same with L2 cache but it didn't like my chips. Need to look into what's going on there. Still, 16kB L1 and 64kB L2 is more than most CPUs with 16b memory bus can brag of.
Next step is to benchmark my ISA and VLB VGA cards on it to see how they scale with this CPU/bus, then decide which to use with it permanently. Also (and relevant to that choice) I need to figure out what to do with the system as a whole. IBM design just begs for OS/2 I suppose...
Edit:
Cache problem was simple - with onboard 64kB cache it only needed a 64kbit tag. Replaced that with a 256kbit tag and it suddenly worked fine with 128kB L2 😀
