HWiNFO support of vintage hardware
Reply 180 of 809, by Mumak
CoffeeOne wrote on 2020-03-01, 13:10:
Sure. Now there are temperatures for the first 32 DIMMs hw-info-4094.jpg […]
Mumak wrote on 2020-03-01, 13:03:
CoffeeOne wrote on 2020-03-01, 12:01:
Sure, Looks quite good, but I can't find DIMM thermal sensors. Did I overlook it?
In the attached zip file, there should be the debug file and the htm report.
Please try again with: www.hwinfo.com/beta/hwi64_623_4094.zip
Sure.
Thanks. Looks like there's some issue with the SPD mux, a problem might also be concurrent running of HWiNFO + SIV.
I did a few more updates, can you please try again: www.hwinfo.com/beta/hwi64_623_4095.zip
Reply 181 of 809, by CoffeeOne
Mumak wrote on 2020-03-01, 14:29:
Sure.
I confirm that SIV ran before hwinfo.
Also that time
I ran version 4095 and saw temperatures for all 64 DIMMs, yay.
debug info and report zipped attached
Reply 182 of 809, by Mumak
CoffeeOne wrote on 2020-03-01, 16:14:
I confirm that SIV ran before hwinfo. Also that time I ran version 4095 and saw temperatures for all 64 DIMMs, yay. debug info a […]
Sure.
Also that time
And also all memory modules listed now (except a few ones, which have a damaged SPD) 😀
Perfect, thanks for the testing and results!
Reply 183 of 809, by Mumak
Sure.
Also that time
Could you please make one more try using: www.hwinfo.com/beta/hwi64_623_4096.zip
I'd like to test one more improvement, but not sure if that will work as expected.
Reply 184 of 809, by CoffeeOne
Mumak wrote on 2020-03-01, 17:01:
Also that time
Nope, that's not good:
The attachment hw-info-4096.jpg is no longer available
Reply 185 of 809, by Mumak
CoffeeOne wrote on 2020-03-01, 17:31:
Also that time
And this one? 😀 www.hwinfo.com/beta/hwi64_623_4097.zip
Reply 186 of 809, by CoffeeOne
Mumak wrote on 2020-03-01, 18:01:
That looks good again.
What do you think about the DIMMs with wrong SPD data? Anything to worry about?
Reply 187 of 809, by Mumak
CoffeeOne wrote on 2020-03-01, 18:25:
It looks better, but the modules reported are duplicates and no thermal sensors. I think I'll stop experimenting and stick to what build 4095 did.
As for the wrong SPD, the problem is that some of your modules contain an invalid 1st byte in the SPD (0x04 instead of 0x92 expected). This might cause a problem in some programs, but as long as the BIOS recognizes all modules it's not critical. Perhaps you could use some tools that can overwrite/fix the SPD (i.e. Thaiphoon Burner) to fix this problem, but I think it's a bit unlikely they will support this Xeon machine. Alternatively you might try put those wrong modules into another machine and try to fix it there. Or if you really don't mind buying new ones then yes, go for it..
Reply 188 of 809, by vorob
Sir sir... I've got another laptop with tremendous amount of bugs in HWINFO. IBM ThinkPad R60.
First of all it doesn't report any memory slots in summary windows. In detailed window it reports huge amount of ram slots while in reality its just 2 slots with 2x2gb ram
Then i'm getting this sensor warning. Anything can be done here?
And when i open sensor window i've got one section without titles, and second part with some wrong values like over 100C...
p.s. it is possible to control fans via some custom fan-made utility, any way to add this functionality here?
Reply 189 of 809, by Mumak
vorob wrote on 2020-03-02, 12:35:
Sir sir... I've got another laptop with tremendous amount of bugs in HWINFO. IBM ThinkPad R60. […]
This machine blocks access to DIMM SPD memory, hence it's not possible to provide detailed module information. What you currently see is only the logical memory configuration, not physical modules.
That warning window is just a warning (self explained), you can disable it from appearing.
I will remove the invalid sensor values in the next build.
Reply 190 of 809, by Mumak
Ready for yet another test? 😉 This will be a special one - attempting to access the 7500 Scalable Memory Buffers for the first time.
Since I haven't tried this before, I don't know if it will work. But if it does, we should be able to read additional memory parameters including the Memory Buffer temperatures.
Here the test build: www.hwinfo.com/beta/hwi64_623_4098.zip
Reply 191 of 809, by CoffeeOne
Mumak wrote on 2020-03-02, 15:18:
Ready for yet another test? ;) This will be a special one - attempting to access the 7500 Scalable Memory Buffers for the first […]
Yes:
Seems to be nearly as good as 4095 😁
The attachment hwinfo-5098-main.jpg is no longer available
There are special characters in the DIMM names, that's new.
But joke aside, what should be shown additionally?
Reply 192 of 809, by CoffeeOne
My hwinfo try on the Compaq Proliant ML370:
The attachment hwinfo-ml370-main.JPG is no longer available
Impressive. So please add SPD Info 😁
Have to check what's missing, but looks really good
Reply 193 of 809, by Mumak
CoffeeOne wrote on 2020-03-02, 20:33:
My hwinfo try on the Compaq Proliant ML370: hwinfo-ml370-main.JPG […]
Thanks 😀
The problem with missing SPD is because this machine has ServerWorks OSB4 chip and it doesn't seem to have SMBus enabled, which is required to access SPD.
And since I don't have documentation for this chip, I don't know how to enable SMBus there 🙁
I'll get back to you regarding the issue on Xeon X7 shortly...
Reply 194 of 809, by Mumak
CoffeeOne wrote on 2020-03-02, 20:14:
Yes: Seems to be nearly as good as 4095 :D hwinfo-5098-main.jpg There are special characters in the DIMM names, that's new. […]
Yes:
Looks like the memory buffer access didn't work as I expected, moreover new bugs caused erratic SPD readout 🙁 This is such a crazy machine...
Could you please try this build: www.hwinfo.com/beta/hwi64_623_4099.zip
Reply 195 of 809, by vorob
I think ACPI: LENOVO ThinkPad R60 and IBM ThinkPad EC: LENOVO ThinkPad R60 report the same data, but second thing makes some errors. I was looking at second sensor in OSD and sometimes GPU temperature were 128C, and cooler RPM was much more then i could be.
I used another tool to compare data, and looks like that in ACPI: LENOVO ThinkPad R60
Temp 1 - APS
Temp 3- GPU
Temp 2- CRD
Sad thing is that fan rpm is in "broken" sensor part...
Other things are not important from my point of view.
What is LENOVO 946154G (Intel (G)MCH) with no data?
Reply 196 of 809, by Mumak
vorob wrote on 2020-03-03, 12:41:
I think ACPI: LENOVO ThinkPad R60 and IBM ThinkPad EC: LENOVO ThinkPad R60 report the same data, but second thing makes some err […]
Temp 1 - APS
Temp 3- GPU
Temp 2- CRD
The "Intel (G)MCH" item is the chipset sensor, but it doesn't provide valid data on this system.
Reply 197 of 809, by Mumak
Yes:
Meanwhile I have 2 new builds, would be great if you could test both and provide results as I'm not sure which method will work better. Here they are:
- www.hwinfo.com/beta/hwi64_623_4099.zip
- www.hwinfo.com/beta/hwi64_623_4100.zip
Sorry for so many requests, but it's difficult to develop/test such system remotely. We (I and Ray) were already considering buying such machine, but none of us is yet keen on spending several hundreds of EUR just for a couple of days of testing...
Reply 198 of 809, by CoffeeOne
Mumak wrote on 2020-03-03, 13:14:
Meanwhile I have 2 new builds, would be great if you could test both and provide results as I'm not sure which method will work […]
Yes:
for both versions debug and report in htm
Reply 199 of 809, by Mumak
Some good news for elder geeks 😀
HWiNFO32 version 6.23 Build 4105 Beta finally brings back support of Windows 95. Tested was OSR2, note that some GUI controls might require installing IE4 (OSR 2.5).
