Reply 340 of 809, by Mumak
- Oldbie
phantom_pl wrote on 2020-05-04, 16:18:In my case nothing is fixed 🙁
Both boards (FIC 486-GVT-2 and Shuttle HOT-409) report and display wrong CPU clock (FIC is almost there in the report, but not on the display).
Report + HWiNFO printscreens + CHKCPU before&after screens are attached.
I haven't been able to determine why is this yet, but I have added a new feature - Debug Mode.
Please run this new build including the -d parameter. That will also produce a file called HWINFO.DBG, which includes more insider details that might help me to determine what's going on there.
Please run HWINFO twice with this parameter: along with the -r parameter and without it in case it's showing different clock speeds while running manually and in automatic report generation mode.
Don't forget to backup the DBG file produced from previous run since a new run will overwrite it.
Also when running manually, it should be sufficient to just open the Mainboard info screen and btw you don't need to take photos of the screen - pressing the F2 key will save the content of the actual screen into HWINFO.LOG
[build pulled, newer available]
