Reply 300 of 441, by CuPid
feipoa wrote on 2020-05-21, 10:39:
Oh no. Is there any instruction you can send to the CPU that only an IBM 486BL3 will return a unique response?
None that I know.
I need a vacation.
Reply 301 of 441, by Mumak
It's a shame IBM did implement MSRs (which are standard P5 instructions), but didn't care to spend a few more transistors on CPUID as well.
In DOS it's no problem to re-route the interrupts and catch the fault (i.e. GPF, or as The Uncodumented PC says a Double-Found that can occur as well), but I don't have an idea how one could do this in 9x Kernel/VxD.
I just looked at NuMega VtoolsD and one file caught my attention - vfault.h. What do you think Franck?
The class library provides classes that facilitate hooking faults.
Reply 304 of 441, by RayeR
BTW after 2 years I updated my small CPUID info tool for DOS/Win/Linux
http://www.rayer.g6.cz/programm/programe.htm#CPUID
Reply 305 of 441, by Imperious
Overclocked IBM/Cyrix MII PR166@200mhz, and stock AMD K6 266 (66X4). I am curious why cpuz has no problem detecting fsb and multipliers on
the 6x86 chips but can't on the AMD K6 on the same Motherboard which is a EPOX EP-MVP3G5. The K6 is not a k6-2
Reply 306 of 441, by red-ray
Imperious wrote on 2020-06-29, 12:45:
On the MII the multiplier comes from the Cyrix DIR0 register and on a K6-2 from MSR C0000087, but I don't know if a K6 has MSR C0000087. Can you boot NT4, W2K of WXP? If so then check if SIV reports it on Menu->Hardware->CPUID->CPU-0. We can't sensibly check if MSR C0000087 exists using W9X as it does not support kernel mode structured exception handling.
file.php?id=87036
Reply 307 of 441, by Mumak
AFAIK only K6-2 stepping C (Chomper XT) and later have MSR C0000087.
Reply 308 of 441, by Imperious
Thanks. I should have looked back a page, the same question was asked by Daniël Oosterhuis.
Too much hassle trying to install NT4, XP, or Win2000 on this computer but may try to boot xp off Hiren's boot cd and try Siv in that,
but the questions been answered.
Reply 310 of 441, by pete8475
The Win98 version of CPU-Z causes a blue screen on my Asus TXP4 socket 7 machine.
I'll hook it up tonight and post more details then.
Reply 311 of 441, by CuPid
pete8475 wrote on 2020-07-18, 18:50:
Thanks for the report.
What CPU is installed ?
I need a vacation.
Reply 312 of 441, by pete8475
CuPid wrote on 2020-07-21, 16:14:
AMD K6-2 400mhz.
I'm booting it up now and I'll take note of what the bluescreen says.
EDIT - Took a picture with my phone.
Reply 313 of 441, by RayeR
Just a guess, couldn't it crash due to used CMOV instruction that is not available on K6? Quiet common problem...
Reply 314 of 441, by red-ray
pete8475 wrote on 2020-07-21, 20:01:
AMD K6-2 400mhz.
Exactly which model? I expect SIV32L will report this, does it and does Menu->File->Save Local run OK please?
RayeR wrote on 2020-07-21, 21:28:
Unlikely as CPUZ runs OK on my K6 (Little Foot).
Reply 315 of 441, by CuPid
Thanks pete8475. Seems like an undesired MSR reading to me. I fix that and let you know.
Edit :
pete8475, can you please try that version and let me know ? if it works, can you please post a TXT report ? Thanks.
https://download.cpuid.com/betas/cpuz_w95_dbg.zip
I need a vacation.
Reply 316 of 441, by pete8475
CuPid wrote on 2020-07-23, 10:23:
Thanks pete8475. Seems like an undesired MSR reading to me. I fix that and let you know. […]
Edit :
Booting it up now! Will post the txt report shortly.
EDIT - Done with no issues.
Reply 318 of 441, by RayeR
Ok, as it run on other K6 CMOV is not the problem. Unknown MSR read can cause troubles too. Is it possible to install own exception handler to catch it before OS BOSD? I neved did it in C...
Reply 319 of 441, by CuPid
pete8475 wrote on 2020-07-23, 14:18:
Thanks. It is strange because the K6-2 is supposed to support the MSR. Well ...
RayeR wrote on 2020-07-23, 17:29:
Not from a VxD unfortunately. I strongly wish it could be possible because that prevents to accurately detect several CPUs.
I need a vacation.
