First post, by overdrive333
1733mhz/256k vs 1400mhz/512kb
I have both of these cpus, but I have only one FCPGA2->FCPGA adapter and I need to choose which processor to modify. 133 FSB is my limit (440bx mb).
P.S. My 1300 is B1 stepping and I'm sure it will work on 1733 at voltage 1.75-1.8 .
Reply 1 of 14, by fosterwj03
I suspect that the Celeron would win most benchmarks at the higher clock speed (with the same FSB). The Celeron will lose out in certain tasks that saturate it's 256K of cache. Rare, though.
I had a 1300MHz Celeron (100MHz FSB) back in the day, and it was a beast!
Reply 2 of 14, by mothergoose729
Definitely interesting. You can make up for a lot of cache misses with 333mhz of additional clock speed.
Reply 5 of 14, by The Serpent Rider
You don't. Test it thoroughly for stability, then proceed. If you can't do that, then your best bet would be PIII-S. Also keep in mind that stable overclock may degrade over time, especially it it's borderline stable.
1733/1400 = ~24% frequency difference
CPU frequency won't make much dent, because high-end PIII's are really starved on slow FSB.
Reply 6 of 14, by darry
overdrive333 wrote on 2021-01-13, 21:45:
cel _9.5 x 133 = 1266 MHz: 7506 3DMarks p3 _9.5 x 133 = 1266 MHz: 7845 3DMarks […]
darry wrote on 2021-01-13, 21:08:
See this Re: Tualatin Celeron vs Williamette Celeron
EDIT: That extra cache really makes a difference .
~4,5%
What video card is that with ?
Reply 7 of 14, by darry
The Serpent Rider wrote on 2021-01-13, 21:55:
You don't. Test it thoroughly for stability, then proceed. If you can't do that, then your best bet would be PIII-S. Also keep i […]
Agreed.
Reply 8 of 14, by mothergoose729
Would you be willing to benchmark both? I would be curious to see how they fair. I am not sure the question is totally settled just yet.
EDIT: Both CPUs benched at 100mhz FSB in addition to 133mhz FSB would also be interesting to see.
Reply 9 of 14, by Standard Def Steve
I actually tried this with a Celeron-1400 back in the day. Had it running at 1866/133, and at that speed it could match the stock-clocked PIII-S 1400 in some benchmarks. In others, the PIII was ahead. The Celeron also required some enormous voltage to get to 1866, and actually quit working after a few hours of benchmarking.
So yeah, definitely go with PIII-S 1400. It'll outperform the Celeron-1733 and run much cooler. Plus, most of them will happily do 1575/150 at stock voltage, should your motherboard accommodate.
Worth noting: I ran those tests on an old Asus TUV4X (Apollo 133) motherboard, which has lower memory performance than 440BX at equivalent bus clocks. That may have allowed the PIII-S and its ginormous cache to shine more brightly than it otherwise would have. 😀
"A little sign-in here, a touch of WiFi there..."
Reply 10 of 14, by mothergoose729
Standard Def Steve wrote on 2021-01-13, 23:06:
Oh, well there you have it 😁
Reply 12 of 14, by H3nrik V!
But it sounds like you had a lot of fun doing it 🤣
Reply 13 of 14, by BigDaddyM
My results from 3dmark 99:
Celeron 1400 - 17213 cpu marks
Celeron 1666 - 20585 cpu marks (c1200 @133 MHz fsb)
Tualatin 1400 - 21760 cpu marks
Reply 14 of 14, by Standard Def Steve
H3nrik V! wrote on 2021-01-15, 07:46:
Well, I was definitely excited when the thing posted and booted into Windows! I mean, a near 1.9GHz Tualatin! I was hoping for some Athlon XP, possibly even ULV Pentium M levels of performance! But then I ran the benchmarks and I was like: 🥱. And then it burned out and I was like: 😠
