cpu upgrade (penitum 200 mmx)
Reply 20 of 32, by alvaro84
GigAHerZ wrote:
You can use the top part of the RAM as RAMDISK with XMSDSK utility.
In your case, it would be a 16MB ramdisk.
I have 256MB of ram in my MMX build, of which 192MB is allocated to a ramdisk.
Can you relocate the swap file to that ramdisk? 🤣
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 21 of 32, by matze79
_UV_ wrote:
You will need Win95 OSR 2 or later build with proper support for MMX, or you may encounter BSOD if software/games try to use it with OS knowing nothing how to handle it.
interesting i run Windows 95A and never encountered this issue.
What games do crash ?
Reply 22 of 32, by Robhalfordfan
i am prob a noob here or a dumb question, what is the benefits of a ramdisk (other than faster transfers speed)
Reply 23 of 32, by GigAHerZ
That's pretty much it - faster speed and lower latency.
The point is, you can have more than 64MB of ram without getting a performance hit because everything over 64MB is not cached.
Reply 25 of 32, by H3nrik V!
When setting up a ram disk - does the software for that actually know what range of the memory is cached, or do you risk that the cached portion is made to a ram disk?
Anyways, I would suspect uncached ram to be faster than mechanical hard disks, nevertheless ..
Reply 26 of 32, by GigAHerZ
XMSDSK has -t parameter to put it's memory range on the top.
Reply 27 of 32, by f1_fan
Robhalfordfan wrote on 2019-04-16, 12:47:
got the mobo (with appropriate parts already there) and over a month later working no problem
Hello, сould you write or take a photo the missing parts?
I plan to restore dual power VRM, so needs the markings on it
Reply 28 of 32, by Robhalfordfan
f1_fan wrote on 2021-02-16, 06:50:
Hello, сould you write or take a photo the missing parts? […]
a pic of original mobo (without bits on them) or the replacement with bits on them
Reply 29 of 32, by f1_fan
Robhalfordfan wrote on 2021-02-16, 12:41:
The second one. With soldered Q1 and U27 bits. Macro photo if possible.
Reply 30 of 32, by Robhalfordfan
f1_fan wrote on 2021-02-17, 13:11:
photos took on my phone and it automatically went to Marco mode but if it actually is - i have no idea but hopefully these will help you
    1.7 MiB
    u27 area
    517.05 KiB
    q1 bit on vrm
Reply 31 of 32, by f1_fan
Robhalfordfan wrote on 2021-02-17, 14:52:
Perfect! Thank you very much! Now it looks more possible to run K6-II 266 on my ver 1 mobo.
Reply 32 of 32, by Robhalfordfan
f1_fan wrote on 2021-02-19, 18:02:
kl, good luck and is the mobo same as mine - atrend atc 1000+
