VOGONS Driver Library
Reply 1140 of 1650, by ThisOldTech
Here's the drivers I got with a Typhoon Sound Systems
Sound Card 16 "Gold" 3D - Based on the Opti 82C924
This includes Win 3.11 & Win 95 Drivers
https://drive.google.com/drive/folders/1Sun_Z … QDZ?usp=sharing
Dunno, might help someone? There's hardly any info online about these cards.
I rescue old PCs and keep them from being recycled... and preserve Dos/Win 3.11 Software on https://www.ThisOldTech.ca.
Current Machine: AST Advantage! Adventure 6066d Cyrix DX50, 32M, 500MB, Vibra16 + CD/Floppy
Reply 1141 of 1650, by Horun
Great work ! Will try to add the last 3 file posts to library this weekend.
Reply 1142 of 1650, by markot
When making copies of driver disks (or any other software), please always try to make disk images of them instead of copying the files separately from the disks. Sometimes the installations programs don't work correctly if the files are copied separately and the installation program is asking for a floppy disk with a certain volume label.
I often use WinImage on Windows to make disk images, so I can recommend that software for making them. But it is necessary to keep the floppy disks write protected, all modern versions of Windows will otherwise modify the floppy disks without asking the user. It creates some hidden directory on floppy disks.
On Linux, command "dd" can be used to make disk images of floppy disks.
Reply 1143 of 1650, by ThisOldTech
markot wrote on 2021-04-30, 07:52:
I'm unable to reply to your PM due to my newbie level of Vogons (my slow transition from being a lurker to a contributor is evident haha) but I've created disk images from the Typhoon Sound Card (Opti 924 chipset) and will do that with all the disks in write-protect from now on.
Floppy images (created w/WinImage) are here:
Reply 1144 of 1650, by markot
Thank you, I will test the floppy images. It is always good to make disk images, because they can also easily be mounted to virtual machines, if needed.
Reply 1145 of 1650, by markot
And if looking at this screenshot, here is the reason why always keep write protection on, if copying files from floppy disks to Windows machines. Windows always makes a "System Volume Information" directory on floppy disks that don't have write protection on. Often this is not a problem, but it is better to avoid.
The attachment sysvolinfo.png is no longer available
Reply 1146 of 1650, by canthearu
Anyone got the DOS drivers for the Smart and Friendly SCSI adaptor 3510A in ISA format?
Seems to be a clone of the DTC 3520 card.
Not having any luck finding a copy of these drivers to test one of these cards I got out of an old Build I bought (no HDD to copy original drivers from).
Reply 1147 of 1650, by cyclone3d
Uploaded the TDK Digital Music Card DMC9000 Disks, CD, updates and translated to English update info and README files:
http://www.vogonsdrivers.com/getfile.php?file … &menustate=38,0
The attachment TDK_Digital_Music_Card_DMC9000_Disks_and_Application_CD_1997.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1148 of 1650, by brt02
Something for the driver DB 😀
Driver CD v1.21 for Abit IC7 Series Motherboards (IC7, IC7-G, IC7 MAX3)
https://drive.google.com/file/d/1vWj7S1CBW7X7 … iew?usp=sharing
Uploaded as an ISO file.
Intel OR840 | Dual P3 1GHz - 1GB PC800 RDRAM - ATI Radeon 9800 Pro - Creative Audigy 2ZS - Lian Li PC-65 - W98/W2K
Reply 1149 of 1650, by Horun
canthearu wrote on 2021-05-08, 02:42:
Can you post a picture of the card ? The archive of DTC says it the 3520 is "Fully compatible with Adaptec's AHA-1520 ISA product".
http://web.archive.org/web/20000614165236/htt … csi/3520a.shtml
edit: found a picture and it has no BIOS (not good for HD's), jumpers for IRQ and Port Address so is closer to a DTC 3510
http://web.archive.org/web/20000304051110/htt … csi/3510a.shtml
"Adaptec 151x/AIC-6X60 Compatible" so should use Aspi2dos.sys
Reply 1150 of 1650, by ruthan
I have question does all Gameport Joysticks working without any drivers, or some of them need some drivers for DOS or Windows?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1151 of 1650, by Horun
ruthan wrote on 2021-05-27, 02:15:
All Analog Joysticks and Gamepads work in DOS w/o drivers on a Gameport, the number of buttons and axis is limited to 4 buttons and 4 axis. You need drivers to use more than that and most better quality have Windows drivers so all axis and buttons work.
Win95 is when Digital/Analog joysticks came out with multi buttons and axis (example: MS 3D Pro Joystick with 8 buttons, joystick, top hat, throttle, etc. In analog mode under DOS only the main joystick and 4 buttons work unless game directly supports more)
Not sure if that helps. Probably better to ask in the general Old Hardware section as others may have better info
Reply 1152 of 1650, by cyclone3d
Some stuff that has more than 4 button daisy chains off the keyboard port, such as Thrustmaster sticks, throttles and pedals.
No DOS drivers, but you do have to program the controllers.
YMF7x4 Guide
Reply 1153 of 1650, by ruthan
Ok, thanks for info i have this one:
Logitech WingMan Extreme Digital 3D with Gameport
https://www.youtube.com/product/E_g_11vs2fkxj … Glja2VyLlVTLmVu
- there pictures with some bundled cd..
And searching for drivers. I tried it with Win98 Gamepad control panel, but i didnt got any response.. other joysticks work well with same test. So it could be dead.
In vogons library is driver for
3D Pro model.. and some other Logitech drivers, but there is not list of supported devices for some drivers, so im not sure if there are for it..
http://www.vogonsdrivers.com/index.php?catid= … menustate=26,25
But maybe its lost cause if test is failing.. I also order some USB gameport adapter, but it take month to get it.
Reply 1154 of 1650, by Horun
Going thru Logitechs archives it says it works with Logitech WingMan Software v3.x and up which is a Win95/Win98 driver +profiler package, it does not work with Logitech Entertainment Software which has DOS support.
From the LWS 3.3 readme.txt:
"3. DOS AND WINDOWS 3.X
Logitech Wingman Software is designed to work with the Windows 95/98
operating systems only. Windows 3.x and true DOS (6.22 or lower) are not supported.
LWS does support DOS games that run in a Windows 95/98 DOS box."
From some previous Vogons topics other say it is Digital only and the USB to Gameport adapter allows connecting to older sound cards but runs in a digital only mode.
Reply 1155 of 1650, by ruthan
Thanks.
Reply 1156 of 1650, by Pierre32
Squall / fellow uploaders, what's the procedure for updating zip contents in a driver I've already uploaded?
Reply 1157 of 1650, by Horun
Pierre32 wrote on 2021-05-31, 12:05:
As far as I know you can edit most anything on your post except the actual file you uploaded.
SquallStrife can remove the entry and then you can re-add it.
PM SquallStrife and ask if he will remove it.
Another choice is to edit the text on current upload and point to an updated post. Still should PM SquallStrife and tell him about it and why....
Reply 1158 of 1650, by Pierre32
Horun wrote on 2021-06-01, 01:25:
As far as I know you can edit most anything on your post except the actual file you uploaded. SquallStrife can remove the entry […]
Cheers bud. I think I'll go with the comprehensive option; upload a new one, edit the old one, then PM the boss for removal.
Reply 1159 of 1650, by cyclone3d
Uploaded the disks for the IBM ACE (Mwave) sold by Best Data to vogonsdrivers:
http://www.vogonsdrivers.com/getfile.php?fileid=1823
The attachment IBM_MWAVE_ACE_Best-Data_disks_1080.jpg is no longer available
YMF7x4 Guide
