HWiNFO support of vintage hardware
Reply 500 of 683, by Mumak
douglar wrote on 2021-05-10, 14:13:
I have this motherboard: "LION COMPUTERS, INC. NICE GREEN-VL/ISA" http://www.win3x.org/uh19/motherboard/show/3461 […]
Contaq 596a chipset w/ latest HWInfo 6.1.3 from this thread.
Locks up when trying to view motherboard information at "Resetting CPU [Method 1]"
I tried different switches -d -v -r -s with no luck.
I need to do a hardware reset to reboot.
Please go first into the Setup menu of HWiNFO and disable the respective Reset method. That will also save the setting into HWINFO.INI file.
Reply 501 of 683, by douglar
Mumak wrote on 2021-05-10, 14:19:
OK, thanks. It doesn't like Method 1 or Method 2, but runs fine when they are disabled.
    NICEGREE.TXT
    18.08 KiB
    68 downloads
Reply 502 of 683, by Mumak
Thanks for the feedback and report. Unfortunately I can't predict when a particular Reset Method works or not, so it's left to user disabling if needed.
Could you please also run with -d argument and post the DBG file it created? That will give me some more details, i.e. the chipset ID that I can use.
Reply 503 of 683, by appiah4
I just tried the DOS version on my Cx5x86 system and it detected everything perfectly, well done!
Reply 504 of 683, by douglar
Mumak wrote on 2021-05-10, 14:54:
I tried running as "HWiNFO -r -d logfile.txt" and got this error:
124.4 KiB
It exits gracefully after error.
Here is the debug file--
    HWINFO.DBG.txt
    622 Bytes
    73 downloads
Reply 505 of 683, by Mumak
appiah4 wrote on 2021-05-10, 16:01:
Thanks for the feedback. Any report files are welcome for my reference 😉
Reply 506 of 683, by Mumak
douglar wrote on 2021-05-10, 18:36:
I tried running as "HWiNFO -r -d logfile.txt" and got this error: […]
Unfortunately the attached DBG file doesn't capture the screen where it crashed.
But it's quite strange as that test is just a simple read from port 0x3FE. Do you know if there's something in that range?
Reply 507 of 683, by douglar
I had the debug file that didn't have the "-r" switch. Here's the larger file. Still doesn't have much in it.
I only had an IDE controller and a VGA card in the system. I changed to the ISA Trident VGA card I used when troubleshooting and got the same error.
I wish I could find the MR-BIOS for the chipset.
    HWINFO.DBG.txt
    3.1 KiB
    77 downloads
Reply 509 of 683, by Mumak
the_ultra_code wrote on 2021-05-11, 00:41:
Here you go. https://i.imgur.com/i62sPhb.png […]
Mumak wrote on 2021-05-10, 06:34:
Oops 😀 Could you please attach the content of the "HKEY_LOCAL_MACHINE\Software\3Dfx Interactive\Voodoo2\PropPage" node?
Here you go.
Thanks, bug will be fixed in the next build.
Reply 510 of 683, by appiah4
Mumak wrote on 2021-05-10, 19:04:
How do I generate one from the MS-DOS version? I think I have version 6.1.3 by the way.
Reply 511 of 683, by Mumak
appiah4 wrote on 2021-05-11, 07:20:
Either manually pressing F2 will save content of current screen into a LOG file, or automatically using the -r switch. Adding -d will also produce DBG file that contains some more details for me.
Reply 512 of 683, by appiah4
OK I'll do a HWINFO -r -d and save the log, but it may take a few days before I feel like opening up the case (to install a 3D printed 3.5" CF-IDE bracket) and get the files..
Reply 513 of 683, by ultra_code
Tested my Tyan 1672 PPro board under 98SE, and HWINFO kinda has the right idea.
Also, I've noticed this with my FIC PN-6210, but HWINFO has... trouble comprehending SIMMs from the looks of it.
In other news, tested the latest beta-build, and your fixes are indeed working. My FIC PN-6210 and Voodoo2 are being correctly detected (btw, is there a reason why the clocks/TUs of the Voodoo2 can't be shown? just curious). 😀
Builds
Reply 514 of 683, by Mumak
the_ultra_code wrote on 2021-05-16, 12:06:
Tested my Tyan 1672 PPro board under 98SE, and HWINFO kinda has the right idea. https://i.imgur.com/KmMUMHC.png Also, I've notic […]
Thanks for the feedback!
Voodoo2 clocks should be shown, could you please post the content of
Software\3Dfx Interactive\Voodoo2\D3D
and
Software\3Dfx Interactive\Voodoo2\Glide
keys too?
Reply 515 of 683, by ultra_code
Mumak wrote on 2021-05-16, 14:06:
Thanks for the feedback! Voodoo2 clocks should be shown, could you please post the content of […]
and
keys too?
Here you go - contents of both registry folders and another HWINFO report + debug file in the attached zip file.
    more_v2.zip
    27.64 KiB
    58 downloads
Builds
Reply 516 of 683, by Mumak
the_ultra_code wrote on 2021-05-17, 08:57:
and
keys too?
Thanks! Unfortunately those drivers used don't expose the actual clocks via registry and I'm not aware of any other method how this could be detected.
I have studied available documents, but for some unknown reason the registers described don't behave as expected, so we need to rely on registry data here.
Reply 517 of 683, by Deunan
I have a feature request for HWiNFO for DOS - the decompression/decryption of the data structures is very slow when the program is run from a floppy drive. I could play around with DOS buffers and read-ahead but preferably it should work better on a clean boot system as well.
Reply 518 of 683, by ultra_code
Mumak wrote on 2021-05-17, 09:17:
Noted. Thanks!
Builds
Reply 519 of 683, by appiah4
Mumak wrote on 2021-05-11, 07:32:
Here you go, I hope it helps. 😀
