Reply 39280 of 58396, by debs3759
brostenen wrote on 2021-05-31, 16:23:
Intel486dx33 wrote on 2021-05-31, 16:05:
brostenen wrote on 2021-05-31, 15:47:
Well.... Your mac uses eighter 115 or 145 watt in idle, and my media server uses just under 10 watt when going full speed.
You can actually set more than 10 PI's up and run then full hammer, while that mac is running in idle, and still use less power.
When your mac runs full hammer, it eats up power for 26 to 30 PI's going full hammer.
Yeah, I have run the numbers on computer energy consumption. Its also going to be a dual purpose dual boot desktop computer/Media server. Windows/OSX operating systems.
Its a little high on energy costs but should only be in use about 8 hours a day and will be in sleep mode the rest of the time.
What is your monthly electricity bill? Mine is at 65 US Dollars total each month. (aprox 108 KW/H a month)
My monthly bill is only $50 a month at this time of year, and I run folding at home on a GTX 1060. I do have solar panels though 😀
Reply 39281 of 58396, by PC@LIVE
MMaximus wrote on 2021-05-31, 13:28:
PC@LIVE wrote on 2021-05-29, 19:50:
I have done it in the past with other cards, the alternative you suggest of the external battery, instead requires the setting of the jumpers, theoretically it is simple to do, unfortunately I do not have the manual and therefore I do not know how and what are the jumpers to set.
I'm 99% sure that the ext. battery connector is the 4-pin connector next to the barrel battery, and pin marked "1" (closest to the barrel battery) is the positive. It's also likely that the 3-pin jumper block right next to the battery connector is the one responsible for enabling the external battery. You could try changing the jumper setting and see if the board remembers the CMOS settings.
Ok thanks a lot for the info.
It's probably as you say, that 4 pin jumper, should be the battery connection, and the other with three pins should be the one for selection.
I already have a replacement battery to solder, so I should be using that, but I haven't done repairs to the two broken tracks yet, and haven't resoldered the keyboard connector yet, so I can't try to boot.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 39282 of 58396, by wiretap
Man, I use a minimum of 500kWh/mo in the summer. Luckily I just removed the pool last summer - with the pump running I'd be near 2MWh/ mo. 🤣
My Github
Circuit Board Repair Manuals
Reply 39283 of 58396, by debs3759
wiretap wrote on 2021-05-31, 23:40:
Now you're showing off 😀
Reply 39284 of 58396, by wiretap
Gotta keep the computers cool. It's probably because I keep the AC at 71 freedom units.
My Github
Reply 39285 of 58396, by bjwil1991
Bought a parts GameBoy Color since my childhood one broke on me and I have the necessary components (screws, buttons, and membranes) from the busted one.
Reply 39287 of 58396, by blurks
Nice, the ultimate VLB card in the 4MB configuration and still sealed. That's quite the find...
Reply 39288 of 58396, by HanJammer
This rather uninteresting build, but in a supercute case.
Reply 39289 of 58396, by pan069
HanJammer wrote on 2021-06-02, 09:30:
Worth a deep clean I'd say. Even the drive bay face plates are cool. 😀
Reply 39290 of 58396, by kixs
blurks wrote on 2021-06-01, 21:14:
I was looking for ones for a long time... but the time has finally come and it also made a big dent in my wallet. But you just can't say no 🤣
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 39291 of 58396, by HanJammer
pan069 wrote on 2021-06-02, 10:18:
That's the plan. Plastic is very yellow, but overall the case and internals are in perfect condition (there is even original protective film on the display panel).
Reply 39292 of 58396, by mtgmackid
Great looking case!
Bought more cards/etc. from ewaste on the cheap (Diamond V2 is 12mb):
Putting the Promise card in my 386 build to replace my Prime2 controller =)
Reply 39293 of 58396, by HanJammer
Wow, excellent stuff. Especially on the second photo.
Reply 39294 of 58396, by pan069
mtgmackid wrote on 2021-06-02, 14:27:
Great looking case! […]
Great looking case!
Very nice. Look at all those socketed Chips, pun intended. 😀
Reply 39295 of 58396, by liqmat
Great looking case!
Ah yes, the SIIG CyberPro serial card. Had a handful of those at one point. Not super useful in modern times, but still nice to look at.
Reply 39296 of 58396, by bjwil1991
Won this beauty (well, needs TLC and repairs): an IIT Wedge 486 laptop with a weird top display cover.
Seller's photos:
The attachment IIT-Wedge-Front.jpg is no longer available
The attachment IIT-Wedge-Cracks.jpg is no longer available
The attachment IIT-Wedge-Top.jpg is no longer available
Also has accessories (serial Trackpad, 14.4K data/fax PCMCIA modem), the power supply, diskettes, and manuals.
Reply 39297 of 58396, by chrismeyer6
bjwil1991 wrote on 2021-06-02, 23:59:
Won this beauty (well, needs TLC and repairs): an IIT Wedge 486 laptop with a weird top display cover. […]
Seller's photos:
That's a sweet looking laptop. I hope it survives shipping and your able to restore it back to its glory days.
Reply 39298 of 58396, by bjwil1991
Definitely. I'll do a live stream of the system and go over the features.
Reply 39299 of 58396, by tikoellner
tikoellner wrote on 2021-05-20, 08:37:
Got myself an interesting CRT today, which seems to be EGA monitor. It's Thomson 4460D. It requires some adjustment; we'll see if it works at all. I kinda like the design. EGA CRTs seem to be rare - It's the first one I have seen for sale for a long time.
After receiving the monitor yesterday and hooking it up to my new and ugly 286 build, I can now happily announce that the monitor is fully functional and works in all modes (blue/green/orange/RGB). I'm happy to have finally gotten a proper EGA display. The garbage just required changing the position of two microswitches on my graphics card to become a rather nice and crisp image.
The attachment 20210603_092750.jpg is no longer available
