Reply 39640 of 58805, by vad4r
Asus TXP4 + P200mmx
The attachment Asus TXP4.jpg is no longer available
vae victis!
Reply 39641 of 58805, by BitWrangler
Cool, TX are quite nice to work with. Your bottom ISA slot has a pin that needs fluffing up in case you didn't notice.
Reply 39642 of 58805, by vad4r
BitWrangler wrote on 2021-06-30, 11:30:
Oh, thanks for the hint. I didn't notice at all 😀
vae victis!
Reply 39643 of 58805, by debs3759
Now I have to go through my motherboard collection and see if I have a board good enough to use this to it's fullest potential. Not even sure what SS7 boards I have 😀
Reply 39644 of 58805, by Miphee
debs3759 wrote on 2021-06-30, 14:03:
That CPU is silky-smooth like it's never been used. Beautiful.
Reply 39645 of 58805, by aaronkatrini
oh that K6-3+ is so lovely! Nice find debs3759 😀
Reply 39646 of 58805, by bestemor
Where there any more where that came from ?
(and cheap or expensive?)
Reply 39648 of 58805, by debs3759
bestemor wrote on 2021-06-30, 14:57:
It came from an NOS lot that were bought as a group buy on CPU-World. The original seller had listed a tray of them first that someone paid too much for in order to resell at silly high prices. We got what he had left much cheaper. Mine cost me €55 shipped, a very low price for the fastest K6-3 chip 😀 Sadly they were all sold in the group buy.
Reply 39649 of 58805, by debs3759
Miphee wrote on 2021-06-30, 14:21:
Yep, NOS 😀
Reply 39650 of 58805, by Intel486dx33
I have my AMD K6-3+ 450 over clocked to 500mhz and 550mhz running stable.
You can probably get 600mhz out of yours.
Link:
AMD K6-III+@550mhz., Voodoo-3 / 3DFX / MMX / 3D Now (tower)
AMD K6-lll+@500mhz., Voodoo 3000 (desktop)
Reply 39651 of 58805, by debs3759
aaronkatrini wrote on 2021-06-30, 14:53:
Yeah, we got lucky one CPU-World. Group buy handled by a gifted negotiator. The original seller knew that he could have got a lot more from speculators.
Reply 39652 of 58805, by debs3759
Intel486dx33 wrote on 2021-06-30, 15:22:
I have my AMD K6-3+ 450 over clocked to 500mhz and 550mhz running stable. You can probably get 600mhz out of yours. […]
Link:
I might source a waterblock and hook it up to my chiller. See if I can get even higher (guessing 660 is possible with the right cooling)
Reply 39653 of 58805, by Joakim
Water cooling a k6 3+ is absolutely ridiculous. I love it please post results. 😁
Reply 39654 of 58805, by BitWrangler
Gonna need a block for the chipset and mosfets too to wind it all the way out to 140x6 🤣
Reply 39655 of 58805, by cyclone3d
debs3759 wrote on 2021-06-30, 15:24:
Link:
You're going to have issues with condensation with a chiller. Might even get condensation under the heat spreader.
The smd capacitors under the heat spreader can and will get corrosion on and in-between the solder mounts if the condensation stays there.
I did experimenting with K6-2 CPUs and water-cooling and peltier cooling when they were current.
Even tried injecting coolant under the heat spreader and sealing it back up. That didn't end well.
With the peltier under a waterblock, it iced the CPU and surrounding area really quickly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 39656 of 58805, by Living
overkill, a socket A cooler is more than enough, even at 600Mhz
Reply 39657 of 58805, by Intel486dx33
Link:
Just use a BIG copper heatsink and fan like this guy used.
Link: https://youtu.be/LI1_RlVLhu8
Reply 39658 of 58805, by vad4r
The attachment Philips 17Zoll.jpg is no longer available
Philips 107E
17" CRT - just fished for 5€ from the local ad paper
vae victis!
Reply 39659 of 58805, by cyclone3d
Intel486dx33 wrote on 2021-06-30, 16:22:
Link:
Copper is great at soaking up heat... Releasing that heat, not so much.
If you are using a copper heatsink, you want one with as thin of fins as you can find. A big hunk of metal with thick fins is trash.
YMF7x4 Guide
