Reply 60 of 102, by Unknown_K
My first dual CPU rig was a dual PPro 200 server I built around 2000 or so. I also ran RC versions of Win2k on it before it was actually released and loved the performance, eventually buying 2 PPro overdrives for it (kept the original boxes for them too).
Not everybody builds a retro machine for gaming.
Anyway over the years I have purchased some Dual P1,P2, P3 (slot and socket varieties), Athlon MP, XEON, and Opteron boards as either main rigs or just to play around with for fun and the boards/CPUs were pretty cheap at the time. About the only one I wanted and never had was a dual Slot-2 XEON with that massive CPUs because they were never that easy to find cheap.
These days you can get as many cores as you want so buying dual socket boards is pretty much for data centers. Having a dual Opteron single core system (as an example) is more for tinkering then doing anything serious. The AGP Pro slots as nice for messing with old era CAD cards.
Reply 61 of 102, by Doornkaat
darry wrote on 2021-06-25, 06:11:
Doornkaat wrote on 2021-06-25, 06:06:
Remember facing huge lags when running file sharing software while trying to play fps games back in the early 2000s?
Would that have been mitigated by a second CPU?
Were the FPS games being played against online oponents ?
Yes, but
If so, the blame would likely haven fallen on limited upload bandwidth combined with lack of QOS .
we would limit the upload bandwidth for file sharing clients and the ping was always fine when another family member was filesharing on their PC.
Reply 62 of 102, by zapbuzz
How about we do a stock benchmark on our own pentium III setups just to give ideas to each other what we can do to improve our rigs?
Usually I am the little one 😀
I edited this that theres not just dual's being mentioned lately 🤣
Reply 63 of 102, by luckybob
I love a good dick measuring contest, AND I get to be the big spoon?
Sign me up.
Reply 64 of 102, by chrismeyer6
A dual P3 or socket A build may not be "practical" but I sure do love a good dual cpu build. I should rebuild my dual P3 500 build or my dual 850 system
Reply 65 of 102, by maxtherabbit
zapbuzz wrote on 2021-06-25, 17:44:
How about we do a stock benchmark on our own dual pentium III setups just to give ideas to each other what we can do to improve our rigs?
Ok name the benchmark
Reply 66 of 102, by Grem Five
Both of my dual systems were actually cheaper with the same features of most of my single systems so thats why I have them. Probably they only thing my Dual systems dont do well is overclock and I dont care to do that to my retro systems anyway.
One is a 440GX P3 with coppermine support and the other is a 440FX. If I want them to run more like my single slot systems I just put a terminator board in the 2nd slot.
Reply 67 of 102, by zapbuzz
maxtherabbit wrote on 2021-06-25, 21:06:
A safe offering of industry adopted retro benchmarks period correct:
https://benchmarks.ul.com/legacy-benchmarks
Heres a compatable info tool for the hardware list report:
CPU-Z http://download.cpuid.com/cpu-z/cpu-z_1.63-32bits-en.zip
Benchmark requirements:
Test OS would be of course something NT
PCMARK 2002 would be the best one for pentium 3 as windows 2000 and XP driver support strongest for that era (XP is best for DOS box and multimedia signed driver availability)
3DMARK 03 would be best for Pentium 3 AGP on 2000 and xp (05 & later would be best for socket 478 & 775 systems as it uses later direct x features and Most of PCIE of more modern GPU's)
System boot disk should be either simple or RAID boot by BIOS of the motherboard controller or addon card unless theres a SATA card installed due to lack of PATA Disks (they aren't rare they are scalpers stocks)
Doesn't have to be period correct whatsoever what we have is what we got.
Then everyone who says "should I" will see our pride and joy and decide if they can get a thrill forking out the money.
Reply 68 of 102, by zapbuzz
Anyhow in PC MARK 05 the score for my system is 1269 points with all tests selected. It was XP installed got me to use this bench.
Being 1st generation multimedia extensions supported only I am not really surprised with this result (It didn't crash and being so old I am proud of my work and I know Pentium 4 would blow it away). Benching with latest possible bench gives a more real look in comparison with later architecture.
Reply 69 of 102, by BitWrangler
For absolutely no reason whatsoever, I might be joining the fray in a month or two, other things on the go first, but I realised the other day I have 2 sets of 2 identical slotkets, a pair of 1Ghz PIIIs and a P2B-D board sitting in a box (might need repairs) so it's hard to resist giving it a go. I might be thinking of trying OS2 warp or higher, since that is supposed to support multiple cores and allow multitasking of 3x stuff and presumably anything fully compliant with windoze api. I guess one has to have XP for demi-modern trials, but I think I would also have to stick a linux on it to see what it's useful for. Back in the day, the only ppl screwing around with duals seemed to be those with photoshop or rendering interests. Though there was the odd linux head who wanted one core to compile on and one core to carry on working.
Reply 71 of 102, by luckybob
I also have a quad P3-900 as well. I've been meaning to find a case for it.
Reply 72 of 102, by chrismeyer6
Mmmmmm!!! Quad P3 that sounds sexy as hell. I'd like to see pictures of that.
Reply 73 of 102, by luckybob
yessir!
https://imgur.com/a/Z2Qg1bv
I did get 16GB of ram for it. ^.^ I just need to find a proper case. All my super-towers don't have a spot to hold the memory card.
Reply 74 of 102, by chrismeyer6
Wow!! That is a bad ass setup and having 16 gigs is just drop dead sexy. Once you find a case and fun plans for it?
Reply 75 of 102, by luckybob
Game server actually. It should be powerful enough for a team fortress classic server
Reply 76 of 102, by chrismeyer6
I'd agree with that. And team fortress classic is just perfect use for that.
Reply 77 of 102, by Warlord
I got my or840 around 2004. It was still pretty strong until core 2s came ou, around 2006. Thats when I retired it. But I been meaning to rebuild it for awhile now, I just have too many other projects. It runs pretty good with 2003 server xp lited and stripped down to the bare services and gui. It's still fast enough to web browse in 2021 even if its just a little slow loading pages.
I have actually a super duper video card I want to use in it, but suspect it has some bad ddr modules on it. If I'm ever able to fix the card I'll rebuild it.
its one of these. ELSA GLoria II-Pro - 333MHz DDR
http://vgamuseum.info/images/vlask/nvidia/quadroddru.jpg
Reply 78 of 102, by PC Hoarder Patrol
luckybob wrote on 2021-07-08, 23:21:
yessir!
Afraid that beast is a stretch, even for my piddling little SC830P4 - you'll need to get yourself some SC850 goodness 😀
The attachment Pedestal Matrix.png is no longer available
Reply 79 of 102, by H3nrik V!
luckybob wrote on 2021-07-08, 22:53:
You just had my heart stopping for a second there by omitting the "Xeon" part. My brain short circuited in an "is there a thing like quad P3" line of thoughts 🤣
