Reply 100 of 102, by mothergoose729
In the interest of disclosure, I had a small issue with my NuXT board. My VGA CRT monitor was causing enough interference that the board would sometimes fail to boot.
It took a while to figure out what the problem was. It also seems that not all CRT monitors will cause a problem, and of course LCD monitors don't effect it.
For me, I just turn off my monitor before I boot the computer. It doesn't appear to effect normal operation, just the boot sequence, and specifically I think the VGA bios.
I did exchange a board with JD while trying to figure out what the problem is, so it does appear to effect more than just my unit.
I haven't had a reason to test my serial port. I am on revision 1.2.
