Pairing a SB16 with other sound card to fix MPU-401 and CQM.
Reply 60 of 66, by Tiido
It is not possible to disable individual components on YMF71x cards but you can move them to addresses nothing touches, my SETYMF util will allow you to do that.
Reply 61 of 66, by gdjacobs
Crystal Semi cards do allow components like OPL and PCM to be disabled.
Reply 62 of 66, by Zoomer
oh oh! Tiido! *fan attack!*
No, really, how exactly did I miss that project of yours?! Thanks, I'm going to play around with SETYMF!
MB: Asus P3B-F 1.03 (2x ISA)
CPU: PIII-S 1.4GHz/VIA C3 800MHz
RAM: 256MB PC133
Video: GeForce 4600Ti/Voodoo 5 5500/Voodoo 3 3500 for DOS Glide
Audio: SB16 OPL3 + Audigy Platinum Ex
OS: Windows 98
Reply 63 of 66, by Superpuissant
Hey, just sharing my experience: so, like many of you, I recently started my quest for the perfect sound card for dos games. I went though thousands of threads, I read billions opinions, completely lost my mind and spent a fortune in old overpriced pieces of c..p that were supposed to make that p233 and K6-2 500 sound better.
Then I found this topic and it was like, yeah! Let's do that and push it a bit further! So I did the following:
I have modified a SB CT2940 to replace the CQM chip with a YMF289B (and its DAC) - From time to time I replace the CT 2940 with a CT2290 just because it's big and bulky so probably sounds better...
I've coupled it with a Yamaha YMF718 handling the MPU (what a waste!!)
I have added a PCI sound blaster Audigy 2 ZS for windows 98 EAC and soundfonts treats
The CT2940 and the Audigy are linked together with a y jack splitter, so no need to unplug anything when switching between Windows 98 and DOS.
I am now the proud owner of a complete 3 perfectly capable sound cards pasta mess nonsense that works fine most of the time.
Although, depending of the game, the FM is coming either from the Yamaha YMF718 or from the CT2940 (that sound alike to my hear) and it seems that I there is nothing I can do against it.
And that, my friends, is what is keeping me awake at night...
Reply 64 of 66, by Jo22
A few years ago, I successfully mated a Sound Blaster 16 Model CT1740 with a Media Vision Pro AudioSpectrum 16.
If memory serves, I managed to use all resources on both cards by using different values for the SB 1.5 emulation of the PAS16 and the SB16 (disabling the Thunder Board was an alternative, but I liked the idea of two SBs).
The main issue, however, was that the PAS16 used the OPL3 base address as its own control port, too.
While the PAS16 has special circuitry for its OPL3 to make it work, the SB16 has not.
Which resulted in a horrible noise on the SB16's OPL3 when MVSound.sys was loaded during boot.
To fix the noise, I had to run Diagnose.exe.
When the tests were completed, the SB16's OPL3 stopped making noises.
Reply 65 of 66, by Scirocco
Hi. I have the same card model ct2950 that works with the Roland sc-55. I have a problem with the sound blaster because it uploads MIDI to me on port 330, which is the same as Roland. I can't switch the SB to a different MIDI port because it's already in use. How to turn off MIDI completely in SB?
Reply 66 of 66, by SScorpio
Scirocco wrote on 2021-11-14, 12:45:
What are you using to initialize the card? The CT2950 is a PnP card and should be supported by Unisound. You can create a custom SET Blaster variable with the MPU401 setting set to 0 (zero). You can then initialize the other parts of the card while not mapping a port to the MPU401 part. You'll even be able to have the MPU401 disabled, while still having the gameport enabled if you want.
