Reply 41940 of 57170, by WJG6260
- Member
Finally picked up a motherboard I’ve been curious about for some time: the Alaris Leopard VX/Tornado LX. Apparently, this board has a matching CPU/interposer setup that allows it to run an IBM BL3. Fascinating.
I have an Alaris Cougar, so that’s not a bother, but I’d be interested to find one of those some day and see how the performance compares between the two, as the SiS471 is objectively a much more performant chipset than the OPTi499, at least when it comes to memory-intensive benchmarks.
I guess I have a thing for Alaris boards, as I also have a Leopard LX and Leopard. Both are fun pieces to mess with and the 486SLC2 is an interesting chip as well. I’d love to find one of these someday. It’s like the Cougar’s little sibling, with an SLC2 instead of the BL3. I find it almost humorous to have a 386SX-based chip and a full-fat 486 on the same board!
Anyway, attached here is a picture from the seller. It’s on its way, so I’ll update with a proper thread once it arrives and I can test it out. I really need to get caught up on a backlog of things to test and document, but haven’t been in the best condition to do so as of late, but I digress…
The Leopard VX is pretty fascinating. It’s a typical Alaris part—well made, but oddly implemented. The Efar EC802GL chipset, identified by mr_Slug, seems to be a clone of the SiS471, so that’s pretty nice. What’s most interesting, though, is the combination of the SiS471 with an OPTi 82C822 VL-to-PCI bridge chip. Granted, while these OPTi chips are not known for the greatest PCI performance, my hope is that the PCI implementation does not detract from the VLB performance. It’s also equipped with an MR-BIOS, but thankfully that BIOS is already in the collection stored here on Vogons.
I’ll be sure to test this one and report back. I may make a short video about it or something too, just because.
Also, I recently snagged an ABIT KT7A non-RAID, Athlon XP 1700+, and a DataExpert EXP3406 hybrid 386/486 board. The EXP3406 has an OPTi495XLC chipset instead of the usual 495SLC. I’d be interested to see how this compares to my OPTi495SX hybrid board. So far, the fastest hybrid board I’ve used is my APC Predator I Plus, which has the Symphony Haydn II chipset. Unfortunately, the APC board dislikes Cyrix DLCs and TI SXLs and, while it works with these parts, it’s temperamental when it comes to the L1 cache setup and I can’t get it stable enough to run SpeedSys. Everything else seems to work okay (Norton SI, Landmark, &c.). But that’s a project for another day.
The KT7A is probably going to replace my CUV4X PIII setup for now, as I’ve been curious about Athlon XPs and cheap Tualatins have all but dried up…
EDIT: Turns out this is a Tornado 2. And it needs some TLC. Time to do some repairs and find some jumper manuals...
