Reply 34100 of 52940, by newtmonkey
- Oldbie
Purchased:
Compact Flash-IDE adapter with 4GB card.
Background:
Disaster struck!
While installing Windows for Workgroups 3.11, the installer kept having trouble finding the C: drive. I was able to retry a few times and get Windows installed, but the hard drive started acting very erratically, sometimes taking 30+ seconds just to list a directory in DOS. I wondered if something was maybe wrong with the Windows installation, so I deleted Windows and cleared the autoexec.bat/config.sys files, and then reinstalled DOS. Still no good. Went in and reconnected the IDE cable and power cable, but it only got worse; the BIOS could only detect the HD once every 3-4 times I tried.
This morning I went and checked and one of the pins on the IDE connector on the HD had fallen into the connector. I tried gently pulling it back out, but it snapped! I could probably solder it back to together, but I actually would rather not deal with HDs anymore haha.
