Reply 35960 of 57138, by cyclone3d
luckybob wrote on 2020-09-14, 00:26:
I had one of those 7900gs cards when they were NEW and it was dogshit.
How on earth are they worth $250 now?
AGP. In any case, I had a PCIE 7900GS back then. I voltmodded it and put a different cooler on it and had it at a 50% overclock for about a year before it died. Was a pretty nice card with it overclocked that much.
You think $250 is a lot... go look up going eBay prices for an AGP 7950GT.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 35962 of 57138, by appiah4
What exactly is so good about this? It's just another solid BX Slot-1? Can't seem to tell what it has over things like the P2B variants or the BX2000 variants..
Reply 35963 of 57138, by kolderman
Probably has the rare 1/2 agp divider.
Reply 35964 of 57138, by Warlord
The Microstar BXMaster is also a holder of the AnandTech Editor's Choice award
1. It has an UltraDMA/66 controller just like the cubx
2. will support 768mb of ram, supports 1gb ram on BX if registered Dims, supports ECC
3. Supports up to 155mhz Bus
4. 1.3V - 3.5V vcore in .5 increments.
5. All PCI slots support being Masters "BXMaster features a PCI arbiter chip that allows all 6 of those PCI slots to support bus master devices. PCI slots 1 and 6 still share an IRQ, as do slots 3 and 5. Slot 4 shares an IRQ with the onboard USB controller. "The AGP slot can share an IRQ with either the first or the second PCI slots
6. In many review you can see the BX Master is faster than other BX boards.
7. It is a Top Tier BX board. And beat Cubx in benchmarks.
8. They are Rare, much rarer than Asus cubx or other top tier boards.
9. That particular board was recapped, saving me time and money.
10. It Supports Northbridge Core voltage, and had a rare optional Thermal Sensor for it.
11. The Seller Recapped the board, which is a plus.
Sources.
https://www.anandtech.com/show/556/14
Reply 35967 of 57138, by wiretap
I know, it's perfection. 🤣 I love small motherboards for some reason. I should be able to put this in a small mATX case. I've been wanting to do a reverse sleeper 486 DX4 build in a nice Lian Li or Silverstone case.
My Github
Circuit Board Repair Manuals
Reply 35968 of 57138, by Intel486dx33
wiretap wrote on 2020-09-14, 23:31:
I just found one of these today in my garage. I must have bought it a while back and forgot about it.
Reply 35969 of 57138, by Thallanor
That would be awesome. I've been working on a couple projects like this, but I'm always out of time, money, or both. 😀
Reply 35970 of 57138, by Intel486dx33
Actually its this one. “Lian Li PC-A01”
Reply 35971 of 57138, by luckybob
I remember bidding on that lian li case and losing.
Reply 35972 of 57138, by pentiumspeed
Received mATX Asus K8S-LA based made for HP socket 754 using SiS 760S and 964 southbridge, 512MB and Athlon 64 3400+ 89W (2.4GHz) does have 3 phase VRM using ATX 12V 4 pin connector. I have 2Ghz 51W 90nm 3000+ coming to replace this. Would be nice Athlon XP or P4 alternative for 98se so I can run any of the Geforce FX, Geforce2 or Geforce4 at my choosing.
Cheers,
Great Northern aka Canada.
Reply 35973 of 57138, by badmojo
luckybob wrote on 2020-09-15, 00:24:
At least the winning bidder is putting it to good use 🙄
Reply 35975 of 57138, by pete8475
Unfortunately I think you'll find that AT boards don't fit in mATX cases very well.
Reply 35976 of 57138, by TheMobRules
pete8475 wrote on 2020-09-15, 05:38:
On that little board however, only the top PCI slot would be inaccessible in an mATX case, and generally you won't use more than 1 or 2 PCI slots on a 486. But I believe some customizations will be required for the standoffs and the keyboard connector as those probably won't line up.
Reply 35977 of 57138, by alienmannequin
Have been meaning to post these for many years. Anyone have an idea of what they are?
There were a couple of 4 mb PCMCIA flash cards in the lot, which I took out and used for my 200lx and WinCE PDA, but these don't appear to fit any slots that I have.
Reply 35978 of 57138, by Cyrix200+
alienmannequin wrote on 2020-09-15, 08:06:
Have been meaning to post these for many years. Anyone have an idea of what they are? […]
The IBM one is this: http://www.thinkwiki.org/wiki/IC_DRAM_Card . Not sure about the others.
1982 to 2001
Reply 35979 of 57138, by imi
yeah the IBM ones are not PCMCIA compatible, the other "DRAM" cards might be third party RAM cards for IBM, see if they have the same staggered pin layout.
some of the others are probably just flash cards, what PCMCIA was originally created for ^^ just think of them as "oversized CF cards"
