Reply 37660 of 57151, by mwdmeyer
I did a very expensive thing. Looking forward to it!
Reply 37661 of 57151, by Pierre32
mwdmeyer wrote on 2021-01-16, 06:44:
Oh my. I spent too much time finding a low profile PCI video card for an Aptiva system last year. This has me all sweaty. What kind of system is it going into?
Reply 37662 of 57151, by mwdmeyer
Pierre32 wrote on 2021-01-16, 06:56:
Probably a small form factor compaq P3. I'm very happy about the HDMI port as I don't have space for a CRT monitor and my LCD doesn't do VGA and the adapter I have adds a lot of interference.
Reply 37663 of 57151, by Pierre32
Sweet. I didn't even notice the HDMI. Enjoy!
Reply 37664 of 57151, by Tali
Hi!
Normally I do not post in this thread (that's something I should probably change), but over the last couple years I've acquired quite a few interesting examples. This one isn't particularly special in itself, just a motherboard I need for a project.
But there is a longer story to it. What I wanted to build was a Cyrix/IBM 6x86 PR300, and originally I tried with an OEM board by Asus, the SPAX (pretty much SP-97XV, but one PCI slot less, and with onboard video and audio). It also doesn't cost an arm and a leg, unlike the SP-97. Trouble is, the plan was to use GUS in this build, and not just any kind of GUS, but Extreme. And the board just doesn't allow to disable the inbuilt audio. So what I needed was a similar chipset board (I know it worked with a Cyrix), but with no extras. This one is it. Being extremely yellow is a bonus.
Now waiting for it to arrive and holding my breath it is intact.
Reply 37665 of 57151, by PD2JK
Nice board with a clean lay-out, thanks to the integrated south bridge. No need for a heatsink I presume?
Congrats. 😀
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 37666 of 57151, by PTherapist
Ozzuneoj wrote on 2021-01-16, 04:20:
In all seriousness, I can't explain why some have had such reliability issues with nforce 2 boards while others have not. Lets all just be glad current PCs aren't like they were back in the early 2000s, at least stability wise.
Just to add to the nForce 2 debate, I've recently been putting together old gaming builds and the nForce 2 based build was my most troublesome.
Using an MSI K7N2 motherboard, it absolutely didn't like an overclocked CPU, with freezes in games. This board also did not like any AGP Radeon graphics cards, with constant crashes and weird behaviour even just trying to run 3DMark. So I had to put in an AGP GeForce FX instead.
The build now at least runs games, but a couple of specific games cause a BSOD in Windows XP after a few minutes of running, for example - Battlefield 1942 is unplayable and Halo at least caused a BSOD once. CPU doesn't seem to be overheating, everything is clean and no visible bad capacitors on the motherboard either.
I really must try running memtest for an extended period as others have been doing, as I am using dual channel. Running memtest for a short while back when I was having problems did not show up any memory errors.
Reply 37667 of 57151, by Murugan
Got this tank:
Reply 37668 of 57151, by Tali
Murugan wrote on 2021-01-16, 12:09:
Got this tank:
Now that's a sexy case if there ever was one
PD2JK wrote on 2021-01-16, 10:36:
Congrats. 😀
No idea yet, I'm still waiting for the board to arrive. Guess, we'll see when it does. But the SPAX didn't have a heatsink either, so... still no idea 😀
Reply 37669 of 57151, by Murugan
If this drops on you...
Never saw one like this.
I call it Blade Runner :p
Reply 37670 of 57151, by imi
oooh awesome components too :3
Reply 37671 of 57151, by Murugan
I think it was used as a linux workstation or so.
Only strange thing is that the SB16 (CT2290) does not output on SPK but on Line-out and I hear like CD-ROM and HD through the speakers.
Reply 37673 of 57151, by gex85
Predator99 wrote on 2021-01-15, 19:08:
Already arrived. Nothing to complain here :-) I am asking myself why this 8-bit card is called "AT", there should be no reason w […]
Predator99 wrote on 2021-01-12, 16:21:
Dont bid one this one Imi, the interesting card is one the way to me 😀 😀 😀 Including the slot bracket 😀
Already arrived. Nothing to complain here 😀 I am asking myself why this 8-bit card is called "AT", there should be no reason why it shouldnt run on a XT?
Also ordered these from that lot...
Wow, now THAT is an awesome scrap lot find!
My retro computers
Reply 37674 of 57151, by foil_fresh
Murugan wrote on 2021-01-16, 14:14:
Beautiful. Whats inside?
Reply 37675 of 57151, by Murugan
foil_fresh wrote on 2021-01-16, 15:19:
Soyo 025N2 with DX2-66. Barrel battery was leaking with light damage but everything seems to work.
24MB RAM
CT2290 with issues I need to look into
Diamond Stealth Video VLB with extra RAM installed it seems (haven't removed it yet to see it in full)
VLB IO controller
Reply 37676 of 57151, by stoof
OK hol' up, are we just going to let this one slip by without more people freaking out?
This is a brand new 3dfx VSA-100-based video card with hdmi out! Super cool!
If the existance of this card is common knowledge, then I guess I'm late for the party. 😀
Reply 37677 of 57151, by devius
stoof wrote on 2021-01-16, 15:51:
Count me in as someone else also late for the party... I was scratching my head trying to understand how a Voodoo card could possibly have an HDMI out.
Reply 37678 of 57151, by CMB75
Just bought a new Glitch Works XT-IDE rev 4A board and parts kit from Tindie as I wasn’t successful repairing the Blue Lava Systems XT IDE card which didn’t even last for a year 😡
Reply 37679 of 57151, by Repo Man11
PTherapist wrote on 2021-01-16, 11:08:
Just to add to the nForce 2 debate, I've recently been putting together old gaming builds and the nForce 2 based build was my mo […]
Just in case: if you haven't pulled the northbridge chip cooler off, make sure and do so. If all it has is the original thermal paste, it has become petrified and useless by now.
