First post, by d1stortion
I'm planning to get a GF 6200 PCI for my rig, alongside a V3 AGP. Is it enough to simply change the primary VGA BIOS setting to change between those cards?
Reply 1 of 4, by Gamecollector
Yes.
But don't forget - you need two monitors. Or KLM switch. Or dual-input monitor.
Reply 3 of 4, by archsan
Better use them dual input -- save you from wearing your plugs too soon. Plus you will eventually realize that most people are basically lazy... hehe. Actually I prefer this also for switching between a Voodoo1/2 card and main gfx card.
Reply 4 of 4, by d1stortion
Yeah, I had that in mind with the 6200 having a DVI output and the secondary input of my monitor being DVI. 😀 Just meant that it would likely work with a single-input monitor as well, only more tedious to pull off
