First post, by noshutdown
1. the cyrix 6x86 is known for not being a 100% pentium compatible cpu, and i've seen it fail to run a few tests(linx for example). are the 6x86mx, k5, k6 and winchip all 100% pentium compatible?
2. the k5 has two revisions of cores: the earlier ssa5 and later 5k86, are there any performance difference(at same clock)?
3. is the cyrix m2 just a rename(and higher clock) of the 6x86mx, or any performance improvements (at same clock)?
Reply 1 of 2, by Nahkri
2.the later 5k86 has better performance compared to the older revision.
3.The M2 it's the same with 6x86mx, so no performance improvements.
Mb:JetWay 542C Ali Aladdin 5
Pr:Amd K6-3+:400MHZ @ 550 mhz
Ram:256mb
3D:Voodoo 3 3000 16MB
Sound:Turtle Beach-Montego A3dExtreme(Aureal Vortex 1)
Hdd:Maxtor Fireball Plus 8 40g,7200rpm,2mb cache
Os:Windows 98SE
Reply 2 of 2, by nforce4max
When it comes to the Cyrix the later models do run cooler but they all run pretty hot and by far the most of any S5/7/SS7 cpu. You will need a good socket 370/A cooler to handle these espcially the early 6x86 and some of the early M2(re-branded 6x86).
