First post, by noshutdown
1. the cyrix 6x86 is known for not being a 100% pentium compatible cpu, and i've seen it fail to run a few tests(linx for example). are the 6x86mx, k5, k6 and winchip all 100% pentium compatible?
2. the k5 has two revisions of cores: the earlier ssa5 and later 5k86, are there any performance difference(at same clock)?
3. is the cyrix m2 just a rename(and higher clock) of the 6x86mx, or any performance improvements (at same clock)?
