First post, by b_rros
Hi,
I recently got this old desktop with a Pentium 75 MHz, when I boot the PC it appears as a Pentium 100, I guess there's some jumpers in the wrong place. The thing is I can't find what motherboard is this, I googled everything I can see, but found nothing, there's no model nr. or brand in the motherboard, any help, here's the picture:
Reply 1 of 12, by Skyscraper
I have no idea what board it is but the FSB jumper settings is written on the board.
Change the FSB from 66 MHz to 50 MHz. 1.5x66 = 100 MHz ----> 1.5x50 = 75 MHz.
It is very unlikely the board is running at 2*50 MHz.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 2 of 12, by Tetrium
b_rros, if you really intend to find out what board you have, then one place is to look through total hardware 99 (more commonly known as th99, google that) and look through the pictures of Socket 5/Socket 7 boards and see if you can find one that looks veeery similar.
Though personally I wouldn't really bother since, as Skyscraper already mentioned, it seems all important jumper settings are already printed on the PCB.
My retro rigs (old topic)
Report spammers here!
Reply 4 of 12, by Robin4
I thought FIC boards did always used black memory slots. But there are familar to common use VIA chipsets..
A little bit more information from the topic starter should recommend..
Do you have a better picture of the chipset?
Reply 5 of 12, by b_rros
I tried to find it... and failed!!! That page is as good as counting sheeps to fall asleep 😀
And as you said after changing the jumpers as Skyscraper mentioned the board is already recognizing the Pentium 75.
I guess I will use this board to replace my 486 DX 33 MHz and use my AWE32, here it is
Reply 6 of 12, by GeorgeMan
Whoa! Very nice!
Retro1: Athlon XP 3200+ @Arctic cooler | ASUS A7V600 | Radeon 9800XXL 128MB | SB Audigy 2 ZS | 160GB IDE HDD | Win98SE & XP
Retro2: under construction with a PIII 933 or a Tualatin Celeron 1200 and a GF2 GTS 32MB
Reply 7 of 12, by Tetrium
@ b_rros:
Dude, that's one heck of a nice looking rig! 😁
Reply 8 of 12, by idspispopd
A Pentium 75 is often easily overclocked to 90 or 100 MHz so the jumpers are not necessarily wrong, they might have been intentionally set to that position.
Reply 10 of 12, by b_rros
The PC was working fine at 100 MHz, but I will use this PC to replace an old 486 so I don't need the extra 25 MHz 😀
