First post, by b_rros
I recently got this old desktop with a Pentium 75 MHz, when I boot the PC it appears as a Pentium 100, I guess there's some jumpers in the wrong place. The thing is I can't find what motherboard is this, I googled everything I can see, but found nothing, there's no model nr. or brand in the motherboard, any help, here's the picture:
Reply 1 of 12, by Skyscraper
I have no idea what board it is but the FSB jumper settings is written on the board.
Change the FSB from 66 MHz to 50 MHz. 1.5x66 = 100 MHz ----> 1.5x50 = 75 MHz.
It is very unlikely the board is running at 2*50 MHz.
Reply 2 of 12, by Tetrium
b_rros, if you really intend to find out what board you have, then one place is to look through total hardware 99 (more commonly known as th99, google that) and look through the pictures of Socket 5/Socket 7 boards and see if you can find one that looks veeery similar.
Though personally I wouldn't really bother since, as Skyscraper already mentioned, it seems all important jumper settings are already printed on the PCB.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 12, by BastlerMike
it's a FIC board
Reply 4 of 12, by Robin4
I thought FIC boards did always used black memory slots. But there are familar to common use VIA chipsets..
A little bit more information from the topic starter should recommend..
Do you have a better picture of the chipset?
Reply 5 of 12, by b_rros
I tried to find it... and failed!!! That page is as good as counting sheeps to fall asleep 😀
And as you said after changing the jumpers as Skyscraper mentioned the board is already recognizing the Pentium 75.
I guess I will use this board to replace my 486 DX 33 MHz and use my AWE32, here it is
Reply 6 of 12, by GeorgeMan
Whoa! Very nice!
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 8 of 12, by idspispopd
A Pentium 75 is often easily overclocked to 90 or 100 MHz so the jumpers are not necessarily wrong, they might have been intentionally set to that position.
Reply 9 of 12, by carlostex
Take a screenshot when machine is on POST, taking a look at the BIOS string might be a big help to ID the board.
Reply 10 of 12, by b_rros
The PC was working fine at 100 MHz, but I will use this PC to replace an old 486 so I don't need the extra 25 MHz 😀
Reply 11 of 12, by b_rros
I will try that, thanks.
Reply 12 of 12, by Tiremaster400
Nice, love classic Pentiums.
