First post, by maximus
- Member
I have a Viewsonic VG150 LCD which, for some reason, seems to sync 75 Hz better than 60 Hz. Unfortunately, Windows 98 detects it as a generic monitor and won't let me go beyond 60 Hz. Installing Viewsonic monitor drivers doesn't help.
On Windows XP, the catch-all solution to this kind of problem is a utility called RefreshForce. Is there any equivalent tool for Windows 98? I'm currently at the mercy of my display drivers. Some allow refresh rate tweaking, some don't.
I mention RefreshForce only as an example. When I use this monitor with Windows XP, I'm actually able to select any fresh rate from Display -> Settings -> Advanced -> Adapter. Only with Windows 98 is the refresh rate locked at 60 Hz.
