First post, by boxpressed
My custom-made cables for my Music Quest MQX-32M arrived today, and I was able to try them out with the card and my MT-32. I believe that the card and cable are working properly (read below), but I can't get them to interface with my MT-32.
I went to this webpage to get the DIP switch settings and drivers file: http://www.endprod.com/midi/mqx32m.htm
Unfortunately, the page's link to a PDF version of the manual is no longer live. I emailed the owner of the page but haven't gotten a response in about a week.
The drivers file includes a number of utilities. I used one called MQTEST, and it confirmed that my MQX-32M was using address 330 and IRQ 2/9. I needed to use standard midi cables to complete the test (connect the cable's IN1 to OUT1 and IN2 to OUT2), so I believe all cables are functional. Also, the program MQDIAG (Music Quest Utilities and Diagnostics 4.40) recognizes the card at the same address and IRQ. FWIW, the EPROM version is M11-028.
I know that the MT-32 works because I have been using it with SoftMPU. So far I've been testing using Police Quest 1 (remake) and Space Quest IV.
I'm pretty sure that I need to use a program called MQSETUP on the driver disk to initialize the card, but I need the manual because the process isn't intuitive. Does anyone have a copy of the manual or have any experience setting up this particular card? I'm a real noob with the MT-32, so if you could also tell me which "out" cable to connect to which "in" port (and vice versa), I'd appreciate it. Thanks much in advance!
Reply 1 of 3, by Mau1wurf1977
Only one MIDI cable needs to be connected. And it's MIDI OUT from the MPU401 that goes into MIDI IN on the MT-32 😀
My YouTube channel
Reply 3 of 3, by chrisNova777
http://www.oldschooldaw.com/forums/index.php?topic=2385.0
ive just read that this card is directly supported for use with cakewalk for DOS + voyetra sequencer plus gold.. providing 2 seperate MIDI out ports.
its the next best thing to me finding a voyetra v24s for sale.. if i could find one..
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
