First post, by brostenen
Does someone here on Vogons know what this EDO Ram module is?
All I know is, that it might be 60 ns ram...
Reply 1 of 7, by jwt27
Google that number and you'll find a datasheet here: http://www.datasheetfind.com/details/12476478.html
Says it's 4Mx32 (each module, not each chip), so that's 128Mbit, which is 16MB.
Reply 2 of 7, by Stiletto
Google results imply that VIS VM43217805BJSB-6 is:
Manufacturer: Vanguard International Semiconductor
4 X 32Mb 72Pin EDO RAM SIMM SMA72 60ns
Datasheets:
http://www.datasheets360.com/part/detail/vm43 … 38786?comp=6224
http://www.datasheetarchive.com/VM43217805B-datasheet.html
PN Decode from Datasheet:
VIS Product DRAM SIMM (72 pin) 4Mx32 EDO, 2K ref., 2M x 8 DRAM, B component Revision, SOJ, Tin/lead, B PC Board revision, 60 ns
[EDIT] just missed jwt27's post.
do the Fandango!" - Queen
Stiletto
Reply 3 of 7, by brostenen
Thanks. 1000 times. And you all helped me to help myself in the future. Nice. 😜
Had an idea that it was 8+ megabyte, yet not that much. And I have two of them.
They will come to use, when my AWE32 arrive one of the next days.
Reply 5 of 7, by brostenen
JaNoZ wrote:
AWE32 needs 30pin ram, yours won't fit.
I am sorry to spoil the excitement.
Well... True. Sad. Well.... At least I got a good laugh out of it. 😁
Just proves how little I can remember about old memmory. 🤣
Reply 6 of 7, by tayyare
OWC (Other World Computing) still sells 16MB 30 pin SIMMs. They market them as Apple RAMs, but I used them for AWE32, AWE64 (with SIMMConn)and as system memory on 386 builds, all with success.
EDIT: Sorry, I used their 72 pin SIMMs on AWE64 SIMMConn... 😊
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 7 of 7, by n1mr0d
QFT, those OWC modules work well in my CT3980 AWE32. Another seller i recommend is Keystron
VooDoo Power Asus CUBX-E 440BX PIII 1.4GHz GF4 Ti 4600 Voodoo2 SLI 12MB SBLive!+Drive SB16 CT2230 + NEC XR385
Nostalgia pc Vtech Laser Slimline DX4-100 16MB Acumos AVGA1 AWE32 CT3980 Roland MPU 401 MT32 SC88
