First post, by brostenen
Is it possible to say, put a 60 ns and a 70ns module on a AWE32 card?
Reply 2 of 7, by brostenen
I have those two 16 megabyte modules (VIS-60ns).
Then I have one 16 megabyte 70ns.
One 8 megabyte 60ns from IBM.
And finally one 8 megabyte 70ns from Samsung (I think it is Samsung).
They should all come in hand one way or the other. 😜 Thanks 😀
Reply 3 of 7, by JaNoZ
They should work, as long as their paired in same size, since the controller does 16bit's to both rams simultaneous.
But i have never seen any 8 or 16mb 30p simms only 4mb's, care to take some photos of the ram?
Reply 4 of 7, by brostenen
My bad... I really fucked this plan up, did I? 🤣
Have mistaken 72 for 30 pin mem'. How fucked is that? 😁
Reply 6 of 7, by JaNoZ
They look awesome, they are from OWC?
Anyone have ever bought some 32MB FPM from OWC that might want to share a picture.
I have to know if they use micron super flat ic's on their ram, they can run ultra low timings at fast FSB at umc.
Or their signal quality excels.
Reply 7 of 7, by JayCeeBee64
Rank Retired
Retired
JaNoZ wrote:
they are from OWC?
They're actually from MemoryTen. I know this because I got the original receipt quite by accident - I got this memory along with other PC100 and PC133 DIMMS in a small box, and the receipt was at the bottom folded up. MemoryTen still sells it, but OWC is cheaper; only difference I can see is that this 30-pin SIMM has parity, while the one OWC sells doesn't.
Ooohh, the pain......
