First post, by elianda
Hello Vogons,
I did benchmark of 31 ISA VGA cards with 3DBench2, PCPlayer Bench, Doom and VSpeed.
For convenience I put it into this PDF file:
ftp://78.46.141.148/docs/eliandas_isa_vga_roundup.pdf
file.php?mode=view&id=16345&sid=110a1044148ce98f1147253aa4cfbd8a
file.php?mode=view&id=16340&sid=110a1044148ce98f1147253aa4cfbd8a
file.php?mode=view&id=16346&sid=110a1044148ce98f1147253aa4cfbd8a
file.php?mode=view&id=16347&sid=110a1044148ce98f1147253aa4cfbd8a
file.php?mode=view&id=16348&sid=110a1044148ce98f1147253aa4cfbd8a
technical details can be found in the pdf.
Regards
Youtube Channel
Reply 1 of 11, by 5u3
Nice! 😀
I'm kinda surprised by the good performance of the Trident 8900D.
Reply 2 of 11, by Matth79
Some peculiar results, how does a CL5422 beat a CL5428 on some. or are they dependent on the raw CPU to card memory performance which may not reflect advances in the Windows accelerator ... a 5428 is significantly more advanced than a 5422
Reply 3 of 11, by elianda
This is not about performance if used as Windows Accelerator. Also be aware that not just the chipset plays a role, also internal clock, memory timings on the card a.s.o.
For an average ISA card it is not so easy to get this information.
So it can be that this 5422 is faster with ModeX in Doom than the 5428.
Youtube Channel
Reply 4 of 11, by m1so
5u3 wrote:
Nice! 😀
AFAIK the D revision added memory FIFOs, increasing the performance to a lot higher levels.
Reply 5 of 11, by PhilsComputerLab
Excellent work! Should help a lot of people in choosing what card they want to go with.
YouTube, Facebook, Website
Reply 6 of 11, by kixs
Good work... I would also like to see how far can you "overclock" the ISA bus so the card would still work. On a slower system (386DX) this doesn't always have a big affect but with faster ones it does.
I have mixed results with Trident 8900D 1MB cards... some could be almost as fast as Tseng 4000 and some are way slower.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 7 of 11, by Anonymous Coward
I know with ATi cards, there is a configuration program that lets you set the bus as 8/16 bit and the BIOS as 8/16 bit. The default settings aren't necessarily the optimal ones.
Reply 8 of 11, by retrofanatic
Great work...thanks for this elianda...never knew there were so many variations of the tseng labs et4000ax.
Reply 9 of 11, by elianda
I took the VGAWonderXL for benching out of one of my 386 systems. When I configured it I also went through the configuration tool (e.g. I disabled the Bus Mouse). As the Ati graphics Ultra scores nearly identical the configuration should be also good.
Youtube Channel
Reply 10 of 11, by elianda
A small correction:
The CL-GD410 based card is a Video Seven VEGA and the CL-GD510 based card is a Video Seven VEGA VGA.
(They are both named VEGA VGA in the list)
Youtube Channel
Reply 11 of 11, by idspispopd
There is definitively a better Paradise card missing.
