First post, by MrEWhite
Does anyone know where I can get a passthrough cable for a Voodoo 2?
Reply 1 of 14, by ODwilly
Ebay
Reply 2 of 14, by chinny22
Its just a standard male to female vga cable. look around on ebay or wherever and you'll find a short one
Reply 4 of 14, by ODwilly
Around 6 inches I think
Reply 6 of 14, by ODwilly
Look for 1.8m VGA extension
Reply 8 of 14, by tayyare
It's 0.5m, but it's ok I believe (well, I purchased 2 of the same length in the past)
http://www.ebay.co.uk/itm/0-5m-Beige-VGA-Moni … =item29ff02a628
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 14, by wbc
as said before, ~0.8m VGA extension or passive splitter would be sufficient, but beware of cheap cables as they does not have proper shielding or have major flaws in pinout, resulting in missing DDC functions or blurry picture with "ghosty" trails 😀.
--wbcbz7
Reply 11 of 14, by blank001
The problem is finding a high quality short one in my experience. I've seen a number of short ones that create those VGA artifacts (like doubling of edges, etc).
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 12 of 14, by Munx
http://www.newegg.com/Product/Product.aspx?It … N82E16812200792
Using this one atm, quality is pretty good. Only problem is you have to remove those screw-in pins and the metal part is going to get bent a bit.
My builds!
The Underdog - The budget K6
Reply 13 of 14, by chinny22
Came across some old notes over the weekend
If you search ebay for VGAEXTAA6IN You'll find what I use and works well.
I got this from here
Voodoo passthrough cable
Reply 14 of 14, by obobskivich
I'm using a Monoprice cable, this one I think:
http://www.monoprice.com/Product?c_id=102&cp_ … &seq=1&format=2
My Voodoo2 isn't in the next slot down from my 2D card (its actually 3 slots down), so the length really isn't that bad. I've had no problems with image quality - 1080p60 passes just fine from the 2D card, as does 1024x768 at 100Hz. The slim connectors also made it nice for keeping "bulk" off the cards - when I originally tested out my V2 I was using a 6ft extension. That cable worked fine too, but it was heavy, and even with the card mounted in a case and bolted in, it would "sag" somewhat. So going with lighter cables was an objective. I'm sure the 6" 3dfx cable is also light enough too.
