Reply 20 of 64, by Jolaes76
In my experience, in most cases yes, but not always.
I met motherboards in the past that were sowehow picky about brand, where the internal arrengement and even speed rating of the chips were the same. The motherboard would boot with the SST but not the Texas etc.
(For cross-checking, I reprogrammed the EEPROM with another BIOS and put it in an other motherboard and it was working there.)
This is strange in light of the fact that readout voltage is standard for these EPROMs and EEPROMs, it is the programming voltage and stablility that can vary to a great extent. Some chips, especially old (window-type) EPROMs need more juice than prescribed and a finely calibrated burning. (THOSE are the ones you need a higher-end burner for, not some Chinese crap)
AFAICR, there were some weird EEPROMs in my possession as well that behaved the exact same way.
All in all, if you have a decent motherboard like this, you have a good chance that it will work with a variety of compatible EEPROMs.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 21 of 64, by feipoa
I am not sure about any EEPROM. This board uses a 512 kbit EEPROM, which has 28 pins. Most later 486 and Pentium boards come with EEPROM's which have 32 pins and are 1024 kbit.
While this 486SV2GX4 board has solder pads to allow you to solder in a 32-pin DIP, I haven't confirmed that a 1024 kbit BIOS will work. I tried this experiment on a PC Chips M912 motherboard, which also comes with a 28-pin DIP BIOS, but I could not get a 32-pin EEPROM BIOS to function. Only the 28-pin EEPROM BIOSes work.
Reply 22 of 64, by Jolaes76
I swapped EEPROMs and EPROMs between (S) Socket7 boards that have the 32 leg DIP sockets by default, and it mostly works there - although a big EPROM like this cost quite a bit and is erased / programmed quite slowly 🙁
I do not have much experience with 486 boards with EEPROMs.
So it seems this particular Asus board is a no-go.
Reply 23 of 64, by mt777
I tested several options to maximize results.
Bios from EFA 4DMS works but performance is much worse than original from Asus.
Cyrix 120GP, 1MB cache.
    344.15 KiB
Reply 24 of 64, by techweenie
feipoa wrote on 2015-12-22, 20:43:
I have been testing an Asus VL/I-486SV2GX4 motherboard. I have updated the board with the latest BIOS, 0402-1, which allows for […]
I have been testing an Asus VL/I-486SV2GX4 motherboard. I have updated the board with the latest BIOS, 0402-1, which allows for running Intel/AMD/Cyrix DX4/5 chips in L1:write-back mode. No problem there. The problem is this BIOS version no longer has the option to set the L2 cache into write-through mode. The options are "Write-back" and "Auto". The "write-back" option slows the RAM throughput down nearly 3-fold, probably because the BIOS is incorrectly setting the Alter Bit. Setting the BIOS option to "Auto" correctly sets the L2 cache into write-back mode with the expected memory throughput. By the way, I am using 1024KB L2 cache with a 64kx8 TAG.
The problem is that I cannot figure out how to force the L2 cache into write-through mode. Any ideas?
Does anyone know of other SiS 471-based BIOSes with proper support for L1:WB mode I can try?
The Asus BIOS for this board also does not allow for using 4x32MB SIMMs for a total of 128 MB. For some reason, they limit you to 2x32 MB. If I try to install 4x32 MB FPM, the board doesn't show any signs of life. The chipset spec. sheet for the SiS 471 mentions that 128 MB is supported.
BIOS revision 0401 allows you to set L2 to WT and works with L1 WB. However, based on my testing, 0402 with L2 set to Auto is the same as WT mode. Benchmark results between that and 0401 L2 WT are identical. L2 WB enabled is equally bad performance on both versions. This motherboard is a big letdown performance-wise. I've been comparing it to the PC Chips M912 and that board is faster in every single game benchmark when equipped with the Award BIOS.
Reply 25 of 64, by feipoa
Most likely because the dirty bit getting set incorrectly behind the scenes. I've seen many a board do this. I think there was another thread which addressed something of this nature. Someone did some hardware hack with the cache, but then we realised it could be solved via a simpler BIOS mod.
Reply 26 of 64, by GigAHerZ
I did a software hack and got the write-back L2 to work properly on same chipset: Re: 486 cache/ram speed issue with write-back
Reply 27 of 64, by TheMobRules
Here's the updated BIOS for the ASUS board using GigAHerZ's findings. It's the latest official version (0402.001) with a couple of bits swapped from 0 to 1 on register 72 to properly set L2 dirty tag:
0402.zip
43.78 KiB
117 downloads
ASUS VL/I-486SV2GX4 modded BIOS "0402.002"
14.6 KiB
Register 72 swapped bits
Reply 29 of 64, by feipoa
That was one of the threads. Wasn't there one other thread as well? I know I modified the BIOS in MODBIN as well, but in another thread by PC-Engineer, I think.
Reply 30 of 64, by techweenie
The modded BIOS works! Performance is right in line with where it should be, both with L1 WT and WB. The best combination is L1 WT with L2 WB. DRAM Write Burst doesn't work when L1 WB is enabled. It's now tied with the M912 as the fastest non-pci motherboard I've tested. They trade blows within <1% of each other.
Reply 32 of 64, by OzzFan
What flash utility did you use? I'm having trouble locating the right one.
A (mostly accurate) listing of my computer systems: http://www.shelteringoak.com/OzzNet/
Reply 33 of 64, by mockingbird
OzzFan wrote on 2021-01-15, 14:13:
You won't fine a flash utility because the flash chip is an EPROM that needs to be erased with UV light and programmed externally.
(Decommissioned:)
Reply 34 of 64, by OzzFan
mockingbird wrote on 2021-01-15, 16:21:
Ah ok. I don't have one of those. So these aren't flashable EEPROMs? No chance of getting an image file?
Reply 35 of 64, by mockingbird
OzzFan wrote on 2021-01-15, 20:00:
The image file would be the modded BIOS file posted a few posts up.
You can use a flashable EEPROM instead of an EPROM, namely the W27C512.
(Decommissioned:)
Reply 36 of 64, by techweenie
pshipkov wrote on 2021-01-15, 08:36:
How do you test it ?
I see wb+wb doing better.
I use the dosbench pack from Phil's Computer Lab. Keep in mind I'm testing with a SX955 DX2, not a DX4. The DX4 may have better cache optimizations.
Reply 38 of 64, by DonutKing
Hello, sorry to necro an old thread.
I've got a VL/i486SV2 rev 1.7 modded to GX4 using this guide
Specs:
Am5x86-133
16MB single 60ns SIMM
1024kb L2 cache using a 128kx8 for TAG
VLB ET4000w32/p 2MB
VLB Promise EIDE2000 I/O Controller
AWE64 Gold
Gravis Ultrasound Classic
2GB CF card HDD
Sony CDU55E CDROM
I was running the BIOS version linked in this thread but I found that with L1 WB enabled I was getting choppy digital audio, and also some intermittent issues with my floppy drive - I could copy files off it but straight after I would get strange characters in DIR A: output. Presumably there are some DMA issues.
I found that disabling the L1 WB by removing the orange jumpers in the document in the link above fixed my sound issues.
Alternatively, installing a DX4 Overdrive which doesn't support L1 WB mode did not exhibit the issue.
Has anyone had similar issues with a REV1.7 board?
Perhaps BIOS version 0402.001 is not 100% compatible with this version of the board?
Some other questions:
-does anyone know what JP24 does on this board? it is unmarked on my board, and it doesn't seem to match up with any of the manuals I find online. ON my board it is a single jumper near the edge, the manuals usually show it as a group of 3 jumpers for setting the bus speed.
-I find that the BIOS setting 'Local Bus Ready' is somewhat unstable when set to 'Transparent'; I have to set to 'Synchronize' for best stability. Transparent mode gives a small performance boost in benchmarks. Other people have the same experience?
Reply 39 of 64, by GigAHerZ
DonutKing wrote on 2022-01-31, 11:54:
Yes. I've played around with this beauty: QDI V4S471/G locks up with 1024kB of cache [Fixed! Nicer Award BIOS available!]
And "Transparent" did give a bit better memory throughput on VLB videocard in speedsys.
NB! You may want to try that bios from that thread as well. All bioses are really the same if chipset is same. Only options that are visible are different. (And, theoretically, newer dated bios may have something for the chipset, too, but i don't have the capabilities to go that deep...)
