Reply 21 of 27, by Anonymous Coward
Finally, this is found!
Too bad it'll be several months before I'm able to test it.
Is there a small performance gain over AMIBIOS?
Reply 22 of 27, by sonicx
Unfortunately, there is no performance gain. Only support for large disks has been added.
    1.03 MiB
    1.36 MiB
    1009.53 KiB
    1.04 MiB
    1.08 MiB
Reply 23 of 27, by Anonymous Coward
You should run a comparison of the speedsys memory tests.
Reply 24 of 27, by ltning
I finally got mine installed and running in a case, and while it's not exactly a speed demon, it's quite nice.
About the aforementioned VLB VGA compatibility though: I found a card that doesn't work! I have a Tseng ET4000/W32p VLB card that works fine in a number of machines - but not in this one. That is to say, it works as long as the external cache is off, but any attempt to turn external cache on will prevent it from getting past the POST+option ROM stages. All manner of wait states and timing settings have been explored.
I'm suspecting it has to do with the 16-bit bus, which the Tseng (well, this implementation of it, anyway) doesn't like.
I also have a Genoa Phantom64 S3-based card which worked for a while, but then stopped - soon after I started my attempts at overclocking to 40MHz bus speed. I haven't tested in any other machines yet, so I have no idea if the damage is permanent or system-specific..
Right now it's got a different S3 868 card, miroVIDEO 20SD. Seems to work.
Biggest problem right now is the inability to reboot the system using c-a-d or even the reset button! The former hangs the machine, the latter causes no video signal (and no booting).
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 25 of 27, by Predator99
mat919 wrote on 2023-01-30, 17:18:
Anonymous Coward wrote on 2023-01-22, 09:49:
No, this BIOS image is surprisingly still missing.
I have hoarded over some time an extensive collection of MR BIOSes. I just purchased the board with AMI and looking forward to an upgrade, but since I paid a lot of money for it I am afraid to ruin it on the very next day. Is there anything in particular, that would allow me to pinpoint correct version of MR? A string inside the rom?
If you have an advanced knowledge and/or resources to play with and a know-how , to protect yourself from bricking the board I could upload a rom candidate that look promising in my opinion. LMK.
Can you please also upload your collection here if there are some additions?
How about a MR-BIOS ROM file repository?
Thank you:-)
Reply 26 of 27, by iPonRMA
ltning wrote on 2023-03-27, 21:06:
I finally got mine installed and running in a case, and while it's not exactly a speed demon, it's quite nice. […]
I also tried that board with VLB cards: Tseng ET4000s didnt work except one in one VLB, some S3s works some didnt (mostly diamonds, except the Trio64), and the fastest was also an S3 one, a Trio64 STB card:
https://www.youtube.com/watch?v=T0FWZevKlUY
Reply 27 of 27, by Anonymous Coward
I'm pretty sure I tested a Hercules Dynamite Power (et400ow32p) in my Alaris board, and it worked. I was curious and I think I tested my entire pile of VLB cards, and they all worked. Though admittedly I did not test windows drivers.
