First post, by KT7AGuy
Has anybody ever tried to use a DVI-I passthrough with a Voodoo card? Something like these:
http://www.ebay.com/itm/0-3m-1Ft-DVI-24-5-Mal … r-/251624592974
Since DVI-I carries both analog and digital signals, I'm assuming it would work. However, I just wanted to see if anybody else has already tried this before I order a cable.
Thanks
Reply 1 of 4, by FFXIhealer
Test it yourself by plugging a monitor directly into the end of the VGA side of that cable. If you get a picture on the screen, it'll work perfectly fine through the Voodoo cards.
Reply 2 of 4, by Imperious
Just the other day I used a DVI-VGA adaptor with my Voodoo1 pass through cable. Worked fine.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 4 of 4, by Logistics
I don't think anyone has ever cared enough to try it, but I've always been curious about comparing the factory pass-through cable, plus a typical VGA cable to a custom, 5-coax R+G+B+H+V pass-through and VGA cable. I'm just curious if the color will be more vibrant, and what effect it may have on stability at large resolutions, etc.
