First post, by bluejeans
No lever or anything, just has this on both sides:
Looks like you just push down and slide out of the eye hole.
wrote:Looks like you just push down and slide out of the eye hole.
This.
Socket A was pretty tight. Use a screwdriver securely inserted into the notch on the center to push down and then pull the upper end of it towards the heatsink.
wrote:wrote:Looks like you just push down and slide out of the eye hole.
This.
An athlon xp 2200 (1.8ghz) is in there currently, would I really see a real-world performance improvement of 20-25% by putting a 2600 (2.2) in there? Might be more hassle than it's worth.
