First post, by vkcpolice
Hi all. I have a ide DVD burner in my 486 I installed windows 95 with it no problem but I burnt some games to a DVD disc so I could fit more on the disc but windows nor dos will read the disc in windows it just opens the CD drive folder and shows it empty in dos it just comes up with a read error. Can win 95 read DVD discs? It had no issue reading normal CD r burnt discs is there a driver or something I can do to get this working thanks.
Reply 1 of 12, by derSammler
The problem does not lie in the DVD itself, but in the high-level file system used, which is UDF. Windows 95 does not come with UDF support and shows the (empty) Joliet part of the disc instead. However, I'm pretty sure UDF support for Windows 9x can be added by installing e.g. a DVD playback software.
Reply 2 of 12, by Zup
DVD discs are usually recorded using UDF filesystem. Get and UDF driver for Windows 95 and it will work fine (AFAIK, Adaptec used to have that driver).
I'm selling some stuff!
Reply 6 of 12, by clueless1
Maybe you need to burn the discs with ISO 9660 / Joliet file system?
Reply 9 of 12, by clueless1
Try CDBurnerXP and use ISO 9660 file format. It's under the Disc menu ("Change filesystem").
Reply 10 of 12, by DosFreak
Does the DVD drive support the type of DVD media you're using?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 11 of 12, by vkcpolice
Hi tryed iso buster it will read the contents of my DVD drive I got a series key for it but every time I try and copy the contents of the disc to my hard drive it still asks to register even thou I have registered the software. And am running the pro version this is getting frustrating as I can't run win 98 as its too slow and I have no idea how to install 98 lite I only have 100Mhz and 64mb of ram to play with
Reply 12 of 12, by Jorpho
In the left-side pane of the IsoBuster window, under "Track 01", you should have multiple filesystems available. You can identify each one by either looking at the icon, or right-clicking it and selecting Properties.
If you can't copy a file under the UDF filesystem, then it might work if you locate the file in the ISO or Joliet filesystems. If you do not have the ISO 9660 filesystem, then as clueless1 suggested, you will need to use burning software that can be configured to use more than just the UDF filesystem. Make sense?
