First post, by bluejeans
Plucked it out of a machine today, at first thought "damn, I already got a vlb card for $50 from ebay that's not here yet" - went looking for drivers, can't find one for 95. Installed what must be a 3.1 one without realizing, it had a ton of inf drivers for every color and resolution combination (along with small and large fonts) - installed them, windows said it couldn't figure out what res to use and I got an interlaced picture. I thought that just about any card that's vlb would work fine on 95! Apparently not!
Reply 1 of 6, by i486_inside
I would think that the drivers for that card come built in to Windows 95, May be try installing a Direct X 6.1 It contains some updated cirrus drivers, http://www.falconfly.de/directx.htm
Reply 2 of 6, by bluejeans
Went to remove my current driver, now the card isn't in device manager yet it comes up in advanced display properties - with change greyed out. I deleted the two driver files, that still didn't work, even putting a totally different video card in didn't work, going to reinstall windows. Also, running the setup for directx 6.1 prompted me to reinstall - haven't installed it before, and I'm on win95a.
Reply 3 of 6, by i486_inside
Try installing the driver through device manager, use the DXCIRRUS.INF from the drivers folder, Now that I think about it I think I had some issues with the display on my Packard Bell P60 machine that uses a Cirrus card and I think that I used the driver with DirectX to fix it but that was 3 years ago and it was something I did after at like 5am after I had been up all night so I don't remember exactly what I did.
Reply 4 of 6, by bluejeans
I think I'll just wait for my cirrus vlb to come from ebay that has a native 95 driver.
EDIT: that worked fine, thanks!
Reply 5 of 6, by i486_inside
Nice to know my memory isn't failing me, because I couldn't remember if the DX drivers worked or if I had found a working driver on an obscure FTP or if I used one of those questionable driver downloads that includes adware (driverguide I'm looking in your direction.)
Reply 6 of 6, by bluejeans
So duke3d doesn't care how little video ram you have, as long as the card is vlb? Can't even remember if it has more than one resolution now.
