Reply 240 of 1194, by Sphere478
- l33t++
Here are the components from the previously uploaded version. Are these the ones you want to use?
(Pay no mind to board size/shape/component position. Still in flux.)
Though, if you have any preference whatsoever what side gets the parts, now is the time to tell me.
Blavius wrote on 2022-09-11, 06:07:Sphere478 wrote on 2022-09-10, 19:46:If someone wants to post kicad footprints with nets of the two sockets, I might tinker with this a little. (If it is welcome)
No promises,
I’m thinking pin header stack. Two double layer pcbs probably.
You can find the netted circuit and footprints in the attached project. It would be great to have someone with more experience look at this.
Taking a closer look at what you did here the power planes appear to be kinda messed up. The signal trace routing looks relatively tidy and straightforward though for a two layer layout, good job. It could probably have been improved using four layers. Not bad, power planes need some tweaking though a few sections don’t appear to be connected? 😀 not claiming to be an authority, just some stuff that pops out. Good job, I can tell you put some work into it 😀
Btw, it seems like you may understand some of the jdec standards a little better than I and possibly how to do some signaling considerations/testings that I have some gaps in. Obviously I’m nowhere close to a final draft here but if you have any observations or suggestions lemme know.
