First post, by debs3759
- Oldbie
I have been asked to test a Cyrix 5x86-133GP/4X for a friend (he has been offered two weeks wages for it if it works). I can't find some of my 486 motherboards (I'm part way through reorganising my hardware collection), and of those I can find, the PVI-486SP3 is the most likely to support it. Does anyone have the correct jumper settings for it, or a link to the full manual (I found a pdf file with about 20 pages scanned)? I don't want to blow the chip up 😀
I have two of these boards. A revision 1.22 and a later 1.8. If both work, the earlier board will be going on eBay after extensive testing.
I have the latest BIOS (v 3.06 and 3.07 beta) to burn and try as well, if that makes a difference.
