First post, by stelth
hi i have this toshiba 430 pro cdt model and when i try to turn on it shows nothing for the first 10 seconds,then the screen turns green and it stays like this forever,i tried to restart it with ctr+ alt+ del but still doesn't respond,is the HDD broken? when i turned on last year it was working and the OS ran without problems
Reply 1 of 11, by collector
This forum is for running old windows games on NEW (supported) versions of Windows
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 4 of 11, by stelth
any suggestions?
Reply 5 of 11, by Warlord
possibly bad system memory. If you remove the HDD and turn it on without it, that can eleminate if its the hdd or not. If you have more than 1 stick of ram or other modules try single stick swap modules. Other possibility is dead cmos battery but id be surprised if it caused screen corruption. It could be all 3 of these things together. But I would resolve all three questions before id think its something else.
Reply 6 of 11, by stelth
mhhh....i think it's the HDD...long time ago i had a computer with HDD damaged and it didn't do anything,even the CTRLALTDEL didn't work,but the strange thing is that the display turns green after i power on,idk why
Reply 7 of 11, by stelth
Hi
I removed the HDD and turn it on,did nothing and the greenish screen appeared ,then i put the HDD back and the icon turned green for a couple of seconds and did a sound,and it turned the screen green in 10 seconds.
i tried to disamble it,i removed and put back the BIOS batteries,nothing changed.
Reply 8 of 11, by stelth
stelth wrote:
Hi I removed the HDD and turn it on,did nothing and the greenish screen appeared ,then i put the HDD back and the icon turned g […]
Hi
Heres a couple of photos:
It's so strange the screen turns green,1 year ago it turned on briefly with Windows 95 and ran perfectly,seems dead now
Reply 11 of 11, by oeuvre
sometimes the connectors inside old laptops get loose over time... might be worth a try to reseat stuff
