First post, by mheyman
So I finished setting up a retro build I'm working on, hit the power button annnnnd... nothing...
CPU: Intel Pentium III Tualatin 1.4Ghz modded
Motherboard: Asus Cubx-e Rev. 1.01 (came with some capacitors that needed to be soldered back on, which I did)
RAM: 2x 256MB SDRAM PC100
GPU: ATI Radeon 9700 Pro 128MB
Sound Card: Sound Blaster AWE64
Hard Drive: ADATA SU655 120GB NAND 2.5 inch SATA III SSD
When I power up, the fans spin on the cpu and the gpu and the led on the mobo lights up. Other than that nothing else works. I have a feeling that the graphics card I'm using isn't compatible with this board? I tried using the Jumperless setting and switching all the dips to off. Still no luck, any thoughts? There's a chance my soldering of the caps didn't go well but I'm pretty confident those should be fine.
Reply 1 of 4, by The Serpent Rider
You need modded BIOS. Also try to start it with 66 Mhz FSB settings. Tualatin 1.4 Ghz is a bit heavy for VRM, especially with old capacitors.
Reply 2 of 4, by mheyman
Hey thanks for the reply! Are you saying that without the modded bios I'll see nothing on the screen at all?
And to also confirm, should I be setting the dipswitches on the motherboard to these settings? :
CPU/DRAM -> 66mhz
PCI bus -> 33.4mhz
And I guess a final question is, I found a modded bios here: http://www.geocities.ws/tuacubx/. And some more recent ones here: Modified BIOSes for ASUS P3B-F, P3V4X, CUBX and CUBX-E/L but I've never flashed a bios. Do i need floppy discs / floppy disc drive to do it? Are there any good guides for flashing old motherboards?
Reply 3 of 4, by Horun
If you can get the new BIOS file and flasher util to your HD that is better than flashing from a floppy. As far as the actual bios file and setting I do not know.
Did you breadboard test the motherboard with a lessor cpu after fixing the caps and before building the system ?
