Reply 20 of 33, by Skorbin
I owned an EISA computer in the past and still have some files on my NAS. I went through them and found 2 which i haven't seen on your website:
!AMI46E1.cfg
!SIS0002.cfg
I can send them to you, if you like. Not here, though, as this is my first post 😀
Reply 21 of 33, by mR_Slug
Yes I would be interested in them. Do you have the original zip package along with the ECU utility? if so please send the whole thing. My 'database' relies on the file date to sort different revisions. That's why i prefer the zip archives, which maintain that. I've sent you a PM with my email address.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 22 of 33, by Horun
mR_Slug wrote on 2020-05-16, 18:50:
I'm looking for any sources of EISA configuration .CFG files. Does anyone have any? There is no need to check if I already have them, I can do that. So far I've found 259 more .cfg.
I just found some EISA files while searching thru my CDR archives from 1999 of AST stuff. They are the AST EISA machine and card configs.
They are the original AST zips and/or .EXE with floppy make-disk images.
posted here: http://www.vogonsdrivers.com/getfile.php?file … 5&menustate=0,0
Also found some Asus 486 EISA machine .cfg's and posted them here: Re: EISA board won't post. EISA-486a REV. 1.1
added: Nevermind looks like you have all those....
Reply 24 of 33, by Horun
Stumbled on this one for Media Vision PAS16 while digging for PAS files, is different from the ones you have and may be of value or not..
It is different than the !ICU01E0.CFG and !ICU01E1.CFG you have.
Header:
; (C)Copyright Media Vision, Inc., 1993
; All Rights Reserved.
BOARD
ID = "PAS016A"
NAME = "Pro Audio Spectrum 16"
MFR = "Media Vision, Inc."
CATEGORY = "MFC"
    !PAS01.CFG
    3.34 KiB
    32 downloads
Reply 25 of 33, by mR_Slug
Thank you Horun. Can you give it to me in a zip file? I try to preserve the file date, to give some indication of which is the latest version.
Reply 26 of 33, by Horun
mR_Slug wrote on 2021-09-25, 20:47:
Sorry but it came from a website, after re-searching for it found me this .ARJ with same file name and file size,
stuffed it into a 7zip to maintain original file creation, modified, etc data and post here as arj is not allowed.
    PAS01CFG.7z
    1.43 KiB
    32 downloads
Reply 27 of 33, by liqmat
You can find some in the DPT PM2012B/90 EISA controller archive images over @ -0° and of course the ALR 6x6 archive @ Vogonsdrivers a few of us cobbled together.
Reply 29 of 33, by PC Hoarder Patrol
Seem to be a few !ICL ones in here that aren't listed - https://web.archive.org/web/19970706213625/ht … /ext/EX0004360/
"The attached ZIP file is a collection of *.CFG files. It is offered "as is" for
your use when configuring EISA based machines. We have included every cfg file
we have ever come across. There are more than 300 files here.
*EDIT* - you'll find the OVL file for !ICL4200 here - https://web.archive.org/web/19970707043800/ht … 282/80305350.dd
Reply 31 of 33, by Horun
I found some original Gigabyte files thru way back machine while searching for older 486 bios.
These are the original file sets with *.cfg's, cfg.exe, readme's, etc. that may be of value though you already have all the .cfg from inside pa.zip listed on http://66.113.161.23/~mR_Slug/EISA/
Note: 386ps.zip contains only an exectuable with this as a header: "GIGA-BYTE TECHNOLOGY CO.,LTD GA-386PS SETUP PROGRAM Ver. 1.0"
http://web.archive.org/web/20000815200904/htt … web/swother.htm you can download them or just grab my attachment
ga586id.zip ECU for GA-586ID/IM
1. EISA configuration utility for ID and IM
sis.zip ECU for GA-486SA/TA
1. EISA configuration utility for 486SA/TA
pa.zip ECU for GA-486PA
1. EISA configuration utility for 486PA
386ps.zip ECU/Cache setup for GA-386PS
1. EISA configuration utility for 386PS
    Gigabyte EISA configs.zip
    438.91 KiB
    34 downloads
Reply 32 of 33, by PC Hoarder Patrol
mR_Slug wrote on 2021-11-14, 20:39:
thanks, i will add them sometime soon
Here are a few more for some old Intergraph systems, found while rooting around on their old IBBS archive on wayback for another Vogons member - https://web.archive.org/web/19980109140033/ht … bs/ibbsfile.htm
Intergraph.zip
1.39 MiB
25 downloads
Reply 33 of 33, by Horun
Found the CFG and drivers for Maxtech NX32EISA nic while looking for other nic drivers. Two diff cfg's...header of !acc1200 :
"Configuration file name : !ACC1200.CFG 12/06/1991
; For EISA EtherNet Adapter hardware version R00, R01 (long card)
BOARD
ID = "ACC1200"
NAME = "32-bit EISA-bus Ethernet Adapter"
MFR = " "
CATEGORY = "NET"
SLOT = EISA
LENGTH = 195
READID = YES
BUSMASTER = 23
AMPERAGE = 1000
IOCHECK = INVALID
DISABLE = SUPPORTED
COMMENTS = " The 32-bit EISA-bus Ethernet Adapter is a 32 bit EISA
bus master adapter based on SONIC Ethernet controller."
HELP = "32-bit EISA-bus Ethernet Adapter\n
This configuration file allows selection of the following:\n
1. BOOT ROM disable/enable\n
2. Bus master preempt time\n
3. Interrupt channel\n
4. Burst or non-burst transfer\n
5. Physical media selection"
Zipped up the self-extracting .exe and a NS Sonic datasheet, 7-zip can open/read the .exe
Has cfg's, dos, os2, wfw, netware, etc drivers...
    nx32eisa drivers.zip
    333.38 KiB
    4 downloads
