First post, by Almoststew1990
I have a WD1600AAJB Caviar SE IDE hard drive. I would like to limit it from 160GB to 32GB so I can use it in Windows 98. However the jumpers don't have any setting to limit it to 32GB and I've had a look on Google to see if there is. "standard" setting or anything but no luck.
Does anyone know how to limit it? Would using an access mode other than LBA help?
Reply 2 of 5, by debs3759
Grzyb wrote on 2021-02-17, 16:57:
https://man7.org/linux/man-pages/man8/hdparm.8.html
See the "-N" parameter, ie. "Host Protected Area".
If run from Linux, will this retain the settings for a Windows installation? I did read it, but am unclear on whether it just needs setting once and will be as permanent as required.
Reply 4 of 5, by debs3759
Thanks. I might find that useful at some point.
