First post, by Digidreamer
Hi,
techy issues,
trying to boost the storage by adding a CF card to a wyse V10l running windows 98se
I get as far as the ide/??? driver installing, then the screen goes black, some times a get a little square of background appearing, but the systems completely unresponsive.
the pcmcia adapter can go in ok, but so as you add a CF card to the mix, it all goes wrong. don't see any CF card drivers.
I have tried several cards, with the same response, the cards work fine when connected to a IDE to CF adaptor.
Any ideas?
I Like Charity Shops, they're like steam and GOG but cheaper
