First post, by Digidreamer
- Member
techy issues,
trying to boost the storage by adding a CF card to a wyse V10l running windows 98se
I get as far as the ide/??? driver installing, then the screen goes black, some times a get a little square of background appearing, but the systems completely unresponsive.
the pcmcia adapter can go in ok, but so as you add a CF card to the mix, it all goes wrong. don't see any CF card drivers.
I have tried several cards, with the same response, the cards work fine when connected to a IDE to CF adaptor.
Any ideas?
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
