First post, by rodimus80
- Member
Is there a goto Network card for Win 3.11? Every card I have doesn't have Win 3.x drivers. Is there a cheap alternative on ebay perhaps? Or maybe a specific model with great compatibility with Win3.x? Thanks!
3com 3c509 ?
Do not ask Why !
weedeewee wrote on 2021-06-25, 17:54:3com 3c509 ?
Perfect. Just picked up 2 for cheap. Thanks!
A lot of the chipsets around also had a NE2000 mode, so generic NE2000 driver works.
3C509 is my go-to adapter of choice for all my retro systems
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Generally speaking I reach for 3com network cards. They have driver support for basically every OS and they are generally light on the CPU and have excellent throughput
I use a Linksys LNE2000T ISA card, as someone was selling them new-old-stock for like $10 each a few years back, and I have no trouble at all with them, though I'm only using one right now, in the 486 I use to test everything I make with my modern system. Alas, I'm not a network technician, so I can't say if this card is better or worse than others. It just works fine in Windows for Workgroups, and I can access network shares and browse the web just fine, barring the usual limitations for vintage systems.
