First post, by Hoping
Hi, I've found this case from EK computers that is in very bad shape and was going to salvage the parts, but for some reason after removing the radiator and seeing that it has cooper tubes, i thought that maybe this case is more interesting than it looks.
So, having very little experience with watercooling, only refilled some AIO I thought it would be a good idea to ask in the forum.
Were these cases common? It is worth the work of restoring it considering that, I do not have the side panels, the pump is AC and it does not seem to work and the power supply although it works is modified, finally, it has a control board that I don't understand what it was for.
Reply 3 of 16, by PC Hoarder Patrol
Seems to have been a Spanish outfit that developed the Speedplus / Speedplus Pro systems using TEC coolers
https://translate.google.com/translate?sl=aut … lo/ekspeed1.htm
Interesting looking case anyway, so shame about the rust.
Reply 4 of 16, by creepingnet
I'd just pull the liquid cooling, clean/sand/protectant coat the rust, and then throw a 386 or 486 in there since that's the vibe that case gives me.
~The Creeping Network~
Reply 5 of 16, by Hoping
PC Hoarder Patrol wrote on 2021-07-19, 15:58:
I had not found that article, it is interesting to know that it is from the socket A era. I have several computers from that era so I am encouraging myself to try to restore it. The difficult parts will be the support for the cpu block, the side panels that I do not have, and correctly remove the rust.
Reply 6 of 16, by PC Hoarder Patrol
Hoping wrote on 2021-07-19, 16:24:
Hope your Spanish is up to scratch
manual_montaje_kit.pdf
829.74 KiB
52 downloads
Got it from their archived website at
https://web.archive.org/web/20010803030106/ht … ekspeedplus.asp
There's even a basic 3D Flash animation of the case - if your browser wont play it, you can download the Adobe Flash Player projector content debugger at https://www.adobe.com/support/flashplayer/deb … _downloads.html
Speedplus.zip
198.85 KiB
37 downloads
Reply 7 of 16, by Hoping
Wan't to know what's the worst, part of this?
I'm from Spain, I thought that it was made by EKWB because of the name EK computers, and looked for EKWB computer cases. But it seens that there's no relation between them. My english is what's not up to scrath.
Now I need to find the time to try to restore it. For now, I've found that the water pump is an simple aquarium pump, and thinking of the easiest and cheapest way to fix the rust.
Reply 8 of 16, by PC Hoarder Patrol
Maybe one of those rust converter compounds, or just wire brush / sand it down to bare metal and apply some silver primer/topcoat. Funnily enough, the actual case metal looks almost galvanised in your pics.
Reply 9 of 16, by Hoping
Yes, it looks galvanised, but it still had coolant inside the radiator and judging by color and smell, I think it was the typical green car coolant, I think that caused the rust even if the case is galvanised. Aniway, it needs a lot of work and time.
Another thin that bothers me are the side panels, I don't know how to make ones, but the rust go first, if it is to deep maybe I won't have the skills needed to fix it.
Reply 10 of 16, by Caluser2000
Galvanized cages do rust. Its a myth that they wont. On most computers it is just a very small coat. Leave them exposed out in the weather for a few years a most of the galved case will have shown signs of rust.
Reply 11 of 16, by teclillass
Hello hoping,
To remove the rust you can use vinegar and baking soda. The bicarbonate is a catalyst to speed up the process.
Later it would be interesting to give him a primer and a hand of paint. Or paint it with a spray, to protect the metal.
PS: Here is another Spanish, Greetings.
Reply 12 of 16, by Hoping
Update on this project, I am usually too lazy to document my projects but I am documenting this a bit, so I will share it.
Disassembled the box completely and removed all rust by hand with patience.
Then I painted it with a color that caught my attention but I have never been good at painting, and the result proves it. Part of the problem is that I didn't know that galvanized surfaces need special treatment for paint to adhere properly. Luckily the parts damaged by the rust were sanded and the paint would not fall from those areas.
The previous owner glued the lid of the reservoir with cyanoacrylate and also the copper outlets of the reservoir have cyanoacrylate on the threads. So patience is what I have left.
Also the reservor lid is deformed so with the help of my heat gun I hope to be able to straighten it.
Reply 13 of 16, by Hoping
Repaired the cpu block, new handmade rubber gaskets, no leaks. Now it leaks due to the connections of the tubes that the joints will possibly have damaged after so many years. Luckily the pump still works and gives a fairly large flow and is very silent when submerged. Now the problem is the tube connections. I want to keep the "home made" look so I'm looking for a solution, but since I don't have any experience with the subject I have to study my options. I would like to get a connection of the style that the radiator has.
So I'm looking for a connection with that thread and a smooth outlet.
    1.6 MiB
    1.13 MiB
    1.86 MiB
    1.57 MiB
    1.59 MiB
Reply 14 of 16, by BitWrangler
Just get hardware store stainless steel hose clamps for about 50 cents each.
Reply 15 of 16, by Hoping
Sorry, edited the post, I've forgot one photo, the one of the actual tube connectors, I want to replace those with something with an outlet like the ones of the radiator and if I can find pressure clamps, not the ones with the screw, I'll be happy.
Reply 16 of 16, by BitWrangler
Ah, I see now, air tools section may have brass nozzles that fit, automotive section may have brake lines that you can cut off and leave a sleeve to clamp a hose to.
