First post, by Hoping
Hi, I've found this case from EK computers that is in very bad shape and was going to salvage the parts, but for some reason after removing the radiator and seeing that it has cooper tubes, i thought that maybe this case is more interesting than it looks.
So, having very little experience with watercooling, only refilled some AIO I thought it would be a good idea to ask in the forum.
Were these cases common? It is worth the work of restoring it considering that, I do not have the side panels, the pump is AC and it does not seem to work and the power supply although it works is modified, finally, it has a control board that I don't understand what it was for.
