Joseph_Joestar wrote on 2021-10-27, 18:05:
Note that Win98 doesn't work correctly on hard disks larger than 127 GB. I'm not sure if there are any third-party patches which fix this
Personally, I would go for two SSDs in your case
There are many patches out there for Windows 98 and were mentioned in this thread as well, but your SSD solution is very simple. The two OSes would basically ignore each other, there would be no need for boot loaders and cloning 120/250 GB should be easier.
I would partition the Windows 98 SSD in: 2 GB primary (chinny22 advice for Sandisk), rest for data.
The Silverstone SG11 case has a lot of storage options, I could add after a 500GB HDD just for storing ISOs, games and whatever. The only problem is that the motherboard has only two SATA ports, don't know if there is like a "SATA multiplier" or if I should use a SATA to IDE adapter.
leonardo wrote on 2021-10-27, 18:13:
Why don't you name some games/applications you're looking to run? Just looking at the system requirements/recommendations for some titles might be more helpful than scattershot commentary from everyone imagining their games on your stuff. 😀
I totally understand your right point but basically what I want to achieve here is the most powerful machine I could ever imagine for Windows 98 SE with full compatibility, the machine that I could only dream in my wettest dreams. (and I really had those at the time 😁)
So I'd like to play basically with everything that I throw at it that came on Windows 98, I want to turn those demos in full games.
Just 5 minutes ago I remembered Soldier of Fortune (the one that blew my mind because enemies would behave based on where you shot them). If it can reach it, or maybe Half Life 2 and Tomb Raider AOF on XP, I would be very happy. It seems that I "can't hope for more" since more powerful GPUs would break Windows 98 compatibility even if I will have an E4700 and 2 GB of RAM.
Having said that XP, 7, Vista, don't bring me that nostalgia, I don't even know if there are XP games won't run on 10.
