No Video After Capacitor Replacement - TUSL2-C
First post, by Dog
I have a TUSL2-C that seems to be posting, but I can't get a picture out of it.
I tested the machine before the capacitor replacement and everything seemed to be working fine. I was able to get into an OS and get a game running.
The capacitor replacement was then done with a friend that is more experienced than I am with the process, then the motherboard was turned on.
The board gets power and there are no error beeps.
However I can't get any picture out of the board, and I'm a bit unsure what to do now.
I double checked that the video card, power supply, and RAM I was using didn't give me trouble on a CUBX-L motherboard. The video card does not use additional PSU power, but it seems to warm up when the motherboard is left running for a period. This seemed to indicate the GPU is getting power. I also attempted to clear the CMOS by removing the battery and re-seating it. We've also checked for cold solder joints and missing solder.
Does anyone have any ideas?
If needed I'm fine buying another working board to try to step through figuring out what happened. It was intended to be a learning experience, but I'm hoping for any suggestions before I potentially spend money and cause issues on a second board.
Reply 2 of 21, by Dog
I haven't seen a POST card before now. I'll try to pick one up.
I do know it was tested half way through the replacement and worked, so its definitely possible there was a faulty capacitor.
Reply 3 of 21, by quicknick
Just an idea. Asus boards are notorious for having the silkscreen on the caps the wrong way around (solid white or hatch pattern at the positive terminal instead of the negative). If you and your friend didn't pay attention to this, the caps might be installed backwards.
Reply 4 of 21, by Dog
That is a good call quicknick as this is one of those boards. However they are in the orientation they were originally installed (backwards from the silkscreen)
I got a post card that will arrive Saturday to see if that gives me any more information.
Reply 5 of 21, by majestyk
I would check all the thin traces around the replaced caps very carefully under a good magnifying glass or microscope for damages / interruptions.
I damaged some thin traces by accident especially on ASUS boards years ago when I was recapping them in a hurry. The coating ASUS used on the soldering side seems to be of a poor quality on some models so even if you do not overheat and don´t apply any force there´s still seems to be a risk of damaging traces besides / around the soldering joints.
Reply 7 of 21, by cyclone3d
Dog wrote on 2021-10-28, 19:09:
I’ll try to take a close look at it. If I think I find something should I use this on it?
https://www.aliexpress.com/item/1005002882744930.html
Those trace repair strips are going to be super duper tiny.
If I have a broken trace, unless the gap is large enough to need an actual strand of wire or bodge wire to repair, I'll just jump the gap with solder. Just have to scrape a bit of the coating off each side of the break so you get to the copper.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 21, by Dog
I got the POST Card and I'm getting a C0 response. If I'm not mistaken this means I need to turn off the shadow configuration, but I'm unsure how to do that without getting in the bios.
Reply 9 of 21, by Doornkaat
Have you considered the BIOS may have become corrupted?
If you or your buddy have a EEPROM programmer you could just reflash it.
Alternatively if you have access to another board with the same EEPROM socket you could attempt a hot flash.
Lastly there's always a chance the board received ESD damage from handling. It's not my prime theory though.
Reply 10 of 21, by weedeewee
Last time I was getting a C0 I was wondering about how to fix it. even removed the cache chips, yet no go, so I placed the cache chips back... always that c0
until I changed the é"pçè!è ram . booted without a hitch or glitch, though that was on a pentium motherboard, not a p2/p3 board. so ymmv.
Do not ask Why !
Reply 11 of 21, by Doornkaat
weedeewee wrote on 2021-11-01, 09:44:
Right! OP doesn't appear to have changed the RAM yet. If you have them try different RAM and CPU before bothering with my BIOS suggestions.😅
Edit: typo
Reply 12 of 21, by mockingbird
Check continuity on the installed caps. Make sure the negative leads are connected to ground, and make sure the positive leads of the VRM are connected in parallel.
What I think happened is that the guy who repaired your board destroyed it... This can happen when the via is torn out while either improperly removing or inserting a cap.
Also, post a list of the capacitors that were installed. If defective caps were installed, then that would also explain things.
A picture is worth a thousand words. Post pics of your friend's work.
(Decommissioned:)
Reply 13 of 21, by zapbuzz
cap testing with multimeter could be bad connections with flux or even reslot the card into motherboard sometimes.
Louis Rossmann channel on youtube shows great surface mount soldering.
Reply 14 of 21, by Dog
I have switched the RAM. I have three sticks that I’ve tested in another machine to boot. I do have a multimeter. I’ll post some pictures in a bit.
Reply 15 of 21, by Dog
I uploaded some pictures here:
https://imgur.com/a/MfweaEE
I took the heat sink off to try to increase visibility, and its my iphone attempting to auto stitch a pano of the board. I can focus on a particular area if someone thinks it'll be beneficial.
Direct links to full res:
https://i.imgur.com/RvPi5oi.jpeg
https://i.imgur.com/g1O7Jay.jpeg
Also for comparison I found some photos here I was trying to compare against:
http://hw-museum.cz/mb/54/asus-tusl2
I need to get a battery for my multi meter, that'll be my next step after work.
Reply 16 of 21, by majestyk
Looks like a short to me.
The attachment g1O7Jay1.jpeg is no longer available
Reply 17 of 21, by Dog
I think you might be right, here is a closer look at that spot.
Reply 18 of 21, by mockingbird
Eh, it's not worth fighting with your friend over.
Get another board and send it to a pro to do it.
(Decommissioned:)
Reply 19 of 21, by Dog
No fighting, I'm just trying to get better at this. Mistakes happen, and as majestyk mentioned earlier its very easy to have this this kind of damage. I just didn't see it.
I feel kinda excited about it.
